performance tweeks
- dodak1967
26 Sep 2008 02:26 #238717
by dodak1967
performance tweeks was created by dodak1967
I am looking for ways to increase the performance of my 1980 kz1000 ltd. Any tips, tricks, mods, or experiences. Any suggestions?
- PLUMMEN
- Thank you received: 104
26 Sep 2008 03:21 #238720
by PLUMMEN
Replied by PLUMMEN on topic performance tweeks
i can think of a couple,just depends on what you want it to do and what you want to spend :laugh:
- dodak1967
26 Sep 2008 10:56 #238775
by dodak1967
Replied by dodak1967 on topic performance tweeks
AS far as money Im open. Im looking at getting every bit of horsepower out of the engine I can. What are your suggestions?
- wiredgeorge
26 Sep 2008 11:31 #238780
by wiredgeorge
Replied by wiredgeorge on topic performance tweeks
I think we are in for another bench racing session. If you don't know how to hop up a bike, don't mess with any of the intermediate tips people will give you but put on a turbo and run at full boost:
www.mrturbo.com/turbo_systems/kawasaki/kz%20gpz%20j%20old.html
Probably want to talk with Jay at Ape Racing, one of our sponsors as he can set you up with a 1428 kit with some low compression, forged pistons and then add the KZ MRTurbo kit. I would be kind of careful running 30 lbs boost. 310hp on a KZ chassis! bwhahahaha
- racer54
- Thank you received: 114
26 Sep 2008 14:27 #238815
by racer54
Replied by racer54 on topic performance tweeks
Don't forget the nitrous. Once the bike noses over from only 30 lbs. of boost, hit that magic button and then you will know what power is!!! LOL Seriously though...do you want a hair dryer, juice or just a normally aspirated motor or a combination. Lots of ways to get power and it really depends on what you plan on using the bike for as to what you can, should or want to do to the motor. Give us more on the intended use and I'm sure we can give you some ideas and combinations that would be right up your alley. How much do you want to spend. Depending on what you want, you may want to do some chassis work to keep that power grounded also. Just remember. it's not just any one part but the combination. All the parts must work together otherwise you can end up with a hard to ride bike. I know APE sells kits that might be interesting and give you some ideas as to what you might want. Check them out at
www.aperaceparts.com
(I think that's right).
- PLUMMEN
26 Sep 2008 20:16 #238857
by PLUMMEN
god i love these guys!:woohoo: anyway what do you really plan on using the bike for?a dragbike motor is of little use on a streetbike(ask me how i know this!:blush: )ive always been a fan of the bigger is better idea when it comes to motors.for reliability ,ridability and ability to run on cheap pump gas its much easier to make power with a big ol torque monster 1197 with a decent cylinder head ,mild cams and small carbs than to build a small motor with monster cams ,lots of compression and lots of fancy stuff the big motor dont need.need to mention with the right parts the bigger motor wont have to turn nearly as many rpms to make power which is perfect for a stump pulling streetbike motor that pulls like a freight train in any gear! now i will sit back and listen to the 1075 guys :laugh:
- dodak1967
27 Sep 2008 03:08 #238888
by dodak1967
what Im hoping to do is to build a fast, no, really fast street bike. I could buy one but I like my kz and plan on keeping it. Im not looking to drag race at the local strip. I want to get about 120 rwhp out of the motor. I dont know if thats reasonable or not and if it is how would get that from the motor and what mods would it take?
- steell
27 Sep 2008 05:29 #238899
by steell
Replied by steell on topic performance tweeks
HOT ROD SUPER STREET AND STRIP - Streetable compression ratios and camshafts
SSR1015
$912.53
1015cc piston kit, K410 cams,
valve spring kit
SSR1075
$912.53
1075cc piston kit, K410 cams,
valve spring kit
SSR1200
$1532.87
1200cc piston kit - with sleeves, K435 cams, sob retainers, tappets, valve springs, cylinder studs.
SSR1325/SSR1385
$2124.23
1327 or 1395cc piston kit,Big block cylinder assembly, K435 cams, tappets, retainers, cylinder studs valve springs.
For the serious performance
enthusiast
www.kzzone.com/kits.html
Pick your poison :laugh:
SSR1015
$912.53
valve spring kit
SSR1075
$912.53
valve spring kit
SSR1200
$1532.87
SSR1325/SSR1385
$2124.23
enthusiast
- Old Man Rock
- Thank you received: 225
27 Sep 2008 05:37 #238901
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic performance tweeks
I'm with Plummen on this one... :laugh:
How fast are you speaking about?
Meaning, stock ~ 140-150mph ain't fast enough or are you wanting to jump off the line quicker...
Turbo maybe but NITROUS on a every day rider street bike???
Holly crap, you guys trying to kill this guy... lol!
Here I was thinking my 1015cc kit with .365 CAMS, Valve head Port & Polish, Keihin 29mm CR Specials and a Kerker where going to be kick ass...
Maybe I'm just getting old.... Poor OMR... Hell, after working on my project coming up on one years time, I'll just be happy the old girl starts/runs after 20 years of no running...
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- dodak1967
27 Sep 2008 05:46 #238905
by dodak1967
Faster off the line, with enough instant power (or close to it) left over for quick acceleration while while riding. No 140-150 isnt fast enough
- mtkawboy
- Thank you received: 16
27 Sep 2008 10:08 #238930
by mtkawboy
Replied by mtkawboy on topic performance tweeks
Send the motor to APE and let him do what ever he wants, your just talking the talk on here. Bring a fat wallet and walk the walk
- Old Man Rock
27 Sep 2008 11:03 #238935
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Top end components as Steell provided plus all the other necessities that would be required...
Such as... Crank welded and balanced, transmission cut, head valve job plus, grossly enlarged carbs, new exhaust, frame support, extended swing-arm (possibly single sided), fabrication for nitrous components and not to mention new suspension and brakes required for these speeds....
I'm with mtkawboy where 150mph isn't fast enough :blink: right...
If you're not drag racing this bike on weekends at the strip, using and expecting this to maintain as a daily rider, where are you truly riding this fast and how often... Come on now, be real.
Look at the ergos on brand new sport bikes. These bikes are made for that 180mph speed where engine, suspension ergos and brake system are engineered for it.
The LTD isn't, plain and simple. Hell, none of these old bikes are to that point. That's one of the reasons they called them widow makers when they first came out. Even at 140mph, people were dying left and right to where the Gov tried to ban them.
At 180mph, shit, that will pull your ass off that bike in a heart beat. Road pizza...
Seriously, a little acceleration increase with some CAMs, 1075cc kit and some 34mm carbs is more than enough power.
If you're truly racing this bike then totally disregard but since you posted even asking this question I seriously doubt that being so... 150mph isn't fast enough for any of us on this forum is pure B.S.
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
