ggggggggggrrrrrrrrrrrrrrrrrrrrr
- judgie
23 Sep 2008 09:10 #238340
by judgie
forever tweeking aircooled engines, well it is my job
77 z650c1
ggggggggggrrrrrrrrrrrrrrrrrrrrr was created by judgie
right have spent the day tweeking
stock 650 motor with pod filters and a kerker system with baffle
timing is spot on and have tried variours differant set ups today ranging from 20 max advance to 50 max advance no set at40 max and seems very happy at that.
points and condensor are spot new and set right
compresion tested and there all even and good
coils are getting 12volts and are new as are the leads and plugs
carbs have been stripped and cleaned and rebuilt
started with 110 mains and have gone through my collection up to the biggest i have 125 and it still wont rev out
if you pin it to the stop it just bogs, you can get it to rev to baout 7500rpm but it wont go above.
only thing i have not checked is cam timing as the engine was ment to have had a top end overhaul before i brought it.
it is starting to wind me up now and its not fun to ride as when ever you crack the throttle hard you dont know if its going to rev or not.
any ideas?
cheers rob
any ideas?
cheers rob
77 z650c1
- Bullitt03737
23 Sep 2008 09:50 #238347
by Bullitt03737
1980 CSR 1000. New dyna Coils, Vacumn Less Petcock, Various Handle bars depending on the day, (Drag and Clubman.)
Replied by Bullitt03737 on topic ggggggggggrrrrrrrrrrrrrrrrrrrrr
I was working on a 750 Twin that did the Exact same thing.
It would run real good and then just suddenly hit a wall and
stop accelerating.
Turned out the problem was that the plug wires were all ate
up where they screwed into the caps. I cut it back about a 1/4"
and screwed the cap back on. Presto. Reved pretty good. But
still had jetting issues.
stop accelerating.
- bubbap
- Ride it like you stole it!
23 Sep 2008 11:40 #238356
by bubbap
1979 KZ650, Mac 4-2 exhaust. Restored after 25 years of sitting. Dyna elec coils, ignition. As old as I am, been in the family since new.
Replied by bubbap on topic ggggggggggrrrrrrrrrrrrrrrrrrrrr
I had some similar problems on my 650. I would say it could either be your idle mixture circuit (choke) is plugged or your valve clearance could be off. If its the idle circuit it just needs cleaned out. If its the valve clearance you need to pull the cover and use feeler guages to check your clearance between the cam lobes and the valve tappets then find the right shims. An easy way to tell if its valve clearance is if there is any clacking sounds from the top end.
- martijn
- Thank you received: 1
23 Sep 2008 12:14 #238358
by martijn
Replied by martijn on topic ggggggggggrrrrrrrrrrrrrrrrrrrrr
judgie wrote:
that concerns me, can be off timing or no valve lash. check it!!
It should run pretty well with 125 mains. running almost the same set up with 130 mains.
:blink:.
only thing i have not checked is cam timing as the engine was ment to have had a top end overhaul before i brought cheers rob
- judgie
23 Sep 2008 13:08 #238361
by judgie
77 z650c1
Replied by judgie on topic ggggggggggrrrrrrrrrrrrrrrrrrrrr
did a bit more tweeking before i left work tonight, opened the points gap up to 16 thou an dits made it a bit better still not clean but loads better.
going to try some bigger jets before the weeks out and going to check the cam timing tomorrow night
i will get to the bottom of this
77 z650c1
