- Thank you received: 540
Fuel Pump faiures/problems
- MFolks
22 Sep 2008 22:19 #238282
by MFolks
Fuel Pump faiures/problems was created by MFolks
I realize we are probably stuck with the alcohol in the gasoline. My question is has anybody noticed an increase in fuel pump failures in the FI bikes or rubber/plastic parts in carbs?
A machinist website I go to had a guy complain he only got 5K miles from his fuel pump in his car and this was the third one!
Alcohol will attack and dissolve rubber and plastic parts in fuel systems.The boating guys have a serious problem as the fiberglass tanks are getting soft and leaking.
Being that most large boats are built around the tank(s) this can become costly very quickly!
Too bad this was not brought up during questions about pros and cons of alcohol in gas..............
- steell
06 Oct 2008 21:41 #240527
by steell
Replied by steell on topic Fuel Pump faiures/problems
How many years has ethanol in gas been the norm?
Seems like at least 10 or so.
- kzr750r1
- Thank you received: 9
06 Oct 2008 21:50 #240530
by kzr750r1
KZ750R1 + 1991 ZR750 = KZR750R1
Better to be shot out of a cannon then squeezed through a tube. - HST
Replied by kzr750r1 on topic Fuel Pump faiures/problems
Dosn't the % have some bearing on where in the country the gas is sold. I remember back in the 80s ethinol was more available in the midwest. Cali has their special O2 rich mixture but don't know the % of ethanol added out here.
- steell
07 Oct 2008 04:38 #240546
by steell
I think it's 10% ethanol, with E85 being 85%.
I think all the pump gas in Indiana is 10% ethanol, excepting E85 of course, and I believe it's been that way for a long time. No hard facts to back this up, just some dim recollections
- BSKZ650
- Thank you received: 14
07 Oct 2008 05:40 #240555
by BSKZ650
77 ltd1000, current rider
76 kz900, just waiting
Replied by BSKZ650 on topic Fuel Pump faiures/problems
out here,, Houston area, the pumps say contains up to 10%, I dont recall seeing any e85 here, although, I did fill up in Kansas city with the e85, it was 25 cents a gallon cheaper, didnt know any better, fuel mileage sucked and the truck didnt run quite right for a few tank fills after.
- Mcdroid
- Gone Kwackers
- Thank you received: 318
07 Oct 2008 05:45 #240556
by Mcdroid
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Replied by Mcdroid on topic Fuel Pump faiures/problems
All the mix in Texas is 10% ethanol and has been for several years (except the E85). I have yet to see E85 for sale (although I have been told it is around). I have also not seen any hard data to support the detrimental aspects of burning an ethanol mix...although the warning labels on certain small motors (chainsaws, generators) now mention draining your fuel when storing to prevent the hygroscopic aspect of ethanol = rust.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- saltydog
07 Oct 2008 06:21 #240563
by saltydog
1981 KZ1000 CSR, 1982 KZ440 ltd, 1972 Honda ct90, 1978 KZ 650
Replied by saltydog on topic Fuel Pump faiures/problems
This won't answer your questions, but I thought it might be interesting.
Alcohol is added to the gas after it is loaded on the tanker. The only mixing occurs while the truck is driving down the road. You could actually get alot more alcohol than 10%, or you could get lucky and get less.
Also, some unscrupulous distributors have been known to add more alcohol, because alcohol cost less than gasoline.
