Type of petcock
- stallau
21 Sep 2008 19:31 #238106
by stallau
Type of petcock was created by stallau
The petcock on my hz550-m1 needs to be replaced (one of the screws on the front plate is stripped) and since OEM isn't a possibility just wondering the positives or negatives of going to a on/off version instead of a vacuum as currently installed.
Thanks for the thoughts
- Z1109R Fin
- Thank you received: 1
22 Sep 2008 01:13 #238135
by Z1109R Fin
Z1000R ´83...Slightly modified...
Replied by Z1109R Fin on topic Type of petcock
Pingel....works like a clockwork, no vacuum or other nonsence, flows...
www.z1enterprises.com/detail.aspx?ID=1743
- PLUMMEN
- Thank you received: 104
22 Sep 2008 03:26 #238149
by PLUMMEN
Replied by PLUMMEN on topic Type of petcock
biggest differance is you have to shut fuel off manually
- stallau
22 Sep 2008 19:00 #238257
by stallau
Replied by stallau on topic Type of petcock
Dumb question but I'll feel free to ask. What happens if I forget to turn it off??
- Z1109R Fin
23 Sep 2008 00:35 #238286
by Z1109R Fin
stallau wrote:
If your carb float valves close properly there should be no problem. If they´re not closing you may flood your carbs and engine which is kind of not-so-good. Or fuel drains out from overflow.
