mikuni accelerator pump cover help!!!
- one00three33mhz
19 Sep 2008 10:38 #237790
by one00three33mhz
mikuni accelerator pump cover help!!! was created by one00three33mhz
I have a 79 kz1000 i'm restoring and it looks like a cover for the accelerator pump is missing. Its a triangular cover with three bolts, and three pins on the recessed area.
I was wondering if anyone had a diagram of the accelerator pump for a 34mm smoothbore. I need to know if it has a diaphragm or if its just a gasket. I'd like to just make one out of aluminum and use gasket material and make my own.
feedback pls!!!
regards
Mike
feedback pls!!!
regards
Mike
- Bluemeanie
- Thank you received: 14
21 Sep 2008 11:48 #238035
by Bluemeanie
Replied by Bluemeanie on topic mikuni accelerator pump cover help!!!
Here is a pic of a kit for my 650, yours should be the same. As you can see the 3 hole piece has a diaphram with spring so you will need this cover for it to work properly. I'm sure someone here may have one or know where to get one. Good luck..
