VM26SS question
- sbulla
- 1980 KZ1000 LTD
17 Sep 2008 08:58 #237513
by sbulla
Now----
1980 KZ1000 LTD (Kerker 4-1, K&N pods, Dyna gray coils)
Gone but not forgotten----
1966 Honda 305 Superhawk
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
1995 HD Sportster 1200
2000 HD Softail
2002 KLR650
VM26SS question was created by sbulla
While checking over my '80 LTD I noticed that the accelerator pump rod had fallen off it's upper mounting (along side the return spring). It looks like it needs an E-clip on the shaft to keep it there but, I can't find it on the parts diagram.
I looked locally at some hardware places and can't find one small enough to fit the shaft.
Does anyone know exactly what kind/size of clip I need and where I might find one?
Sonny
Sonny
Now----
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
2000 HD Softail
2002 KLR650
- wiredgeorge
18 Sep 2008 14:50 #237649
by wiredgeorge
Replied by wiredgeorge on topic VM26SS question
Sonny, the smaller eclips are odd sounding numbers. I think it is a 2.3mm eclip that is needed but it may be a 3.2mm, the next size up. No idea where you can buy one of those... hardwares that specialize in fasteners might have them. E-clips go 2.3mm, 3.2mm, 4mm (don't know much about the sizes larger than that except there is also a 7mm). These are the sizes I stock for carburetor rebuilding.
- sbulla
- 1980 KZ1000 LTD
18 Sep 2008 18:06 #237673
by sbulla
Now----
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
2000 HD Softail
2002 KLR650
Replied by sbulla on topic VM26SS question
wiredgeorge wrote:
So it does take an e-clip then. I couldn't make out any kind of clip on the parts diagram I have.
I picked up some today at an Autozone "Help" section that has some small ones in an assortment. Next time I'm in there, I'll see if they fit.
Right now I have it holding on there with some Hillbilly Engineering that I would be very embarrassed for anyone to see but, I wanted to ride.
Thanks for the reply,
Sonny
Sonny
Now----
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
2000 HD Softail
2002 KLR650
- wiredgeorge
19 Sep 2008 06:17 #237752
by wiredgeorge
Actually, I don't THINK they came originally with e-clips. The tip of the spring holding fitting on the bell crank presses through the soft plastic ring in the pump rod. I have seen many that didn't have an e-clip installed and they stayed fine because the plastic was not worn. Once the plastic wears, an e-clip can be installed to keep the pump rod in place. I am not sure if Kaw originally installed e-clips or not for sure.
