GPz 1100
- taffus
15 Sep 2008 14:52 - 15 Sep 2008 14:53 #237259
by taffus
GPz 1100 was created by taffus
Hi All
I have a GPz1100 that has been converted tocarbs which are the BS34 J model ones.
I got the bike already converted and there is a slight but annoying flat spot at 5.5k to 6k. I took the carbs off to check the jetting and the main jet is at 144. The pilot jets are blanked off. The needle is set to the bottom indentation so is at iots richest setting.
I have been advised (in the UK) to go to 130 mains but that seems very small to me, what do you guys think?
TIA
Mark
PS Also posted on WG website (sorry, getting desparate!)
TIA
Mark
Last edit: 15 Sep 2008 14:53 by taffus. Reason: My spelling Duh
- kano
- Not Another Bloody Limey!
15 Sep 2008 14:56 #237261
by kano
Replied by kano on topic GPz 1100
here are my Specs
Gpz1100b1 motor 1170 cc, 3mm over size
laser racing exhaust,
Mikuni bs34mm carbs by WG Carbs,
1 and a half turns out.
Main Jet #142.5
Pilot Jet #40,
K and n air filters, (pods)
hope it helps
Main Jet #142.5
Pilot Jet #40,
hope it helps
