BS34 carb jetting and bench tuning... HELP!!!
- Mekial82kzp
- trying to survive
14 Sep 2008 11:31 #237111
by Mekial82kzp
BS34 carb jetting and bench tuning... HELP!!! was created by Mekial82kzp
Hey, I have a '82 kz1000p that I've been rebuilding into a chopper... I'm about ready to get it running again and I need to bench tune my carbs... I would like to have theme as close as posible before installing them... I'm going to be running pod filters and a open/aftermarket exhaust. I've been told to use #40 pilot jets and #140 main jets... I've even seen a chart to take into account elevation/temp which brought me pretty close to stock. I've also read that is I goto open exhaust and pod filters I should go 1 up on the pilot and 2 up on the main. how do I get the pilot jet out? I can't fit a screwdriver in there... and I assume if I want to work with the air screws I need to remove the carbs from the "carb assambly" or am I wrong? I need help... thanks.
- wiredgeorge
14 Sep 2008 12:01 #237112
by wiredgeorge
Replied by wiredgeorge on topic BS34 carb jetting and bench tuning... HELP!!!
You defintely need to invest in a shop manual. You don't need to remove the carburetors to adjust the mixture screws.
- Mekial82kzp
- trying to survive
14 Sep 2008 22:40 #237190
by Mekial82kzp
Replied by Mekial82kzp on topic BS34 carb jetting and bench tuning... HELP!!!
I know I ask the same question over multiple forum's figure if I ask alot of people I'll have a broader range of information sources to try and distill the best info... I do have a couple manuals but all they say about the air screw is that they are set and pluged at the factory... the picture they give is not the same as my carb... atlease as what I know the air screw to be located.. and it is pluged on all 4 carbs I just can't figure out how to take the pluges out of the carbs where I don't have direct access... thanks.
- Thank you received: 2098
15 Sep 2008 04:49 - 15 Sep 2008 04:52 #237200
by Patton
Replied by Patton on topic BS34 carb jetting and bench tuning... HELP!!!
Here is the oem 1982 KZ1000p carb diagram from Kawasaki.com showing a cv carb with a plug over the pilot adjusting screw and another plug over the pilot jet.
Seem to vaguely recall an earlier thread regarding removal and replacement of the plug or plugs, but am uncertain and don't have hands on experience with these particular carbs.
Am familar with bench synch (to match throttle slide positions), but not with bench tune. Maybe bench tune implies also replacing the jets and adjusting float levels.
Good Luck!
[Click on image to enlarge view]
REF NUMBER PART NUMBER DESCRIPTION QUANTITY US CA CN REMARKS
1 11009-1240 GASKET,CARB. PLUG 4 KZ1000-P1
2 11009-1241 GASKET,FLOAT CHAMBER 4
3 16038-022 "O" RING 4
4 13169-1190 PLATE, LOCK 4 KZ1000-P1
5 14025-1359 TOP-CHAMBER,MIXING 4 KZ1000-P1, KZ1000-P2/P3/P4/P5
6 14043-1010 FILTER,FLOAT VALVE 4
7 16009-1085 NEEDLE-JET 4 KZ1000-P1/P2/P3/P4, KZ1000-P5
8 16012-1010 CAP-STARTER PLUNGER 4
9 16012-1011 CAP-STARTER PLUNGER 4
10 16014-1014 SCREW-PILOT AIR 4
11 16016-1019 PLUNGER 4
12 16017-1086 JET-NEEDLE 4
13 16030-1016 VALVE-FLOAT 4
14 16031-1013 FLOAT 4
15 16055-010 PLATE,NEEDLE 4
16 43028-1025 DIAPHRAGM,VALVE 4 KZ1000-P1, KZ1000-P2/P3/P4, KZ1000-P5
17 16034-001 WASHER MAIN JET 4
18 16008-014 CIRCLIP 4
19 16032-008 PIN,FLOAT 4
20 92055-044 "0" RING 4
21 92055-1059 "O" RING,CHECK VALVE 4
22 92055-1105 "0" RING 4
23 92063-1101 JET-MAIN,#A122.5 4 STD. KZ1000-P1/P2/P3/P4, STD. KZ1000-P5, KZ1000-P1/P2/P3/P4, KZ1000-P5, KZ1000-P5
24 92064-1036 JET-PILOT,#A37.5 4
25 92066-1051 PLUG,PILOT SCREW 4
26 92066-1064 SCREW,DRAIN 4
27 92066-1086 PLUG,CARBURETOR 4 KZ1000-P1
28 92066-1087 PLUG,PILOT JET 4
29 16022-016 SPRING,PILOT SCREW 4
30 92081-1363 SPRING,DPHRGM VALVE 4
31 220B0406 SCREW PAN HEAD 4X6 4
32 220B0510 SCREW PAN HEAD 5X10 14 KZ1000-P1, KZ1000-P2/P3/P4/P5
33 220B0514 SCREW-PAN-CROS 16 KZ1000-P1/P2/P3
34 461F0500 WASHER SPRING 5MM 16 KZ1000-P1/P2/P3
35 223B0518 SCREW-PAN-WS-CROS 16 KZ1000-P4/P5
4-1 13169-1482 PLATE 4 KZ1000-P2/P3/P4/P5
Good Luck!
Last edit: 15 Sep 2008 04:52 by Patton.
- wiredgeorge
15 Sep 2008 06:22 #237206
by wiredgeorge
The purpose of bench sync is to get the slide opening set approximately the same for all four carbs and in the MIDDLE OF THE RANGE OF OPERATION OF THE IDLE SCREW. This isn't an issue with constant velocity carbs so you really don't need to bench sync. It is easier to start the bike if the four throttle butterflies are approximately opening at the same time but the opening at idle is just an eyelash rather than some measureable value like on mechanical slide carbs.
- Mekial82kzp
- trying to survive
15 Sep 2008 07:49 #237221
by Mekial82kzp
ok found the pilot screws... I guess someone in the 21years before I owned the bike pulled the plugs... there was so much grime in there I just thought it was pluged or one of the cylindrical castings in the carb... I always thought the pilot screw was on the side for some reason... like I said found theme, the plugs were removed by someone before me, and some carbs were 2 out and one or two others were 2.5 turns out. By bench tune I meant trying to get the carbs setup as much as posible before installing theme to reduce the number of times I have to pull them off take of a bowl or cap and adjust. thank you.
