sync the carbs .......................... how when you have this situation?
  • School Teacher
  • Topic Author
09 Sep 2008 23:44 #236472 by School Teacher
ok just bought another bike.. yes thats 5 in like a year(but for a grand toatl of 2200 for all five) any way this was the most expensive one ($1000) so it has a wiseco 1075 kit and some 33 smoothies on it. the smoothies have no vacuum port on them and the manifolds don't either. how can i solve this? other than just bench sync. i already have the guage- what to do?
1976 kz900 in parts but will be going some day soon
1980 kz1000G1
1976 kz900 parts bike
1979 kz1000 shaftie parts bike
1978 kz1000 33mm smoothies 1075 kit
Troutdale Oregon USA
10 Sep 2008 05:13 #236485 by wiredgeorge
Learn to bench sync them OR buy a new set of carb holders and find an old set of VM26/VM28 style carb holders and rob the sync fittings. I did this but didn't use new carb holders and the old ones I used don't seal well so I don't use them.
  • Skyman
10 Sep 2008 09:39 #236539 by Skyman
Yeah, I saw that bike on CL. I thought about it. But I couldn't figure out a way to sneak ten bills out without Mrs. Skyman noticing it. :silly:
I'm glad it went to a good home. :)
West Linn, OR
10 Sep 2008 12:32 #236572 by mtkawboy
33 smoothbores require the larger 34mm CV manifolds, wont fit the 26/26 type
10 Sep 2008 13:05 #236574 by ndeli55
can you use a unisynch type tool? like older car mechanics used on dual carbs. i know its more work and time but i dont know why that wouldnt work.
or is it possible to tap the carb holders for a vacuum nipple?
1978 kz650B stock
1973 rd250 (in 1000 pieces)
  • School Teacher
  • Topic Author
10 Sep 2008 14:55 #236588 by School Teacher
sorry don't know what a unisynch tool is(i'll google soon)
but tapping the holders? has anyone tried it? or have ideas on how to go about it?
thanks in advance
1980 kz1000G1
  • School Teacher
  • Topic Author
10 Sep 2008 15:01 #236589 by School Teacher
LOL i have a seperate bike account she don't know about hehe:blink: .....
1980 kz1000G1
10 Sep 2008 15:09 #236591 by racer54
You can buy a carb sync tool that you use on one carb at a time. There are two different versions that I have seen but not sure who sells them. I think Orient Express sells them but not certain. Not sure if Schnitz Racing does or not. You just push the tool into the mouth of the carb to get the reading and move from carb to carb and get the setting right. Never tried it myself but I know that is a tool they use for this type of situation.
11 Sep 2008 12:47 #236707 by 79MKII
The 33's should have vacuum ports on the carb bodies, right? One is used for vacuum style petcocks. Won't those work for synchronizing? I'll double check mine when I get home in case my brain has frozen (again!).
The Kaw List:
  • School Teacher
  • Topic Author
11 Sep 2008 15:31 #236732 by School Teacher
i didn't see any but they are knew to me....
1980 kz1000G1
12 Sep 2008 06:31 #236828 by wiredgeorge
This discussion has produced a lot of interesting info. I mentioned in my post that you can rob the vacuum fittings from old carb holders and put them in the new carb holders. The rubber is pretty tough but it can be done. I have done it. I removed the vacuum ports from the donor set and drilled holes in the new set and sealed them with RTV so they wouldn't leak... took me several hours. Problem was, I didn't want to mess up a new set of carb holders and used some older ones. They didn't seal and were too hard so the effort was a waste of time but I may try again with some new carb holders at some point.
I don't think there is a vacuum fitting on the VM33 assembly.
Last, you CAN NOT sync the carbs with a single gauge. They have a mechanical slide. When you change the slide height on one carb, the others change a bit. So you set #1 carb to 23 on the scale and 2, 3 and 4 change. You put your gauge on #2 carb and set it to 23 on the scale, and #1 changes (as well as 3 and 4). You go back to #1 and find it is now 18 on the scale while #2 is 23... you get the idea. All four have to be adjusted at the same time.
12 Sep 2008 17:10 #236909 by 79MKII
This is the fitting I was thinking of. 3 carbs have fittings, but are they overflows or what?? The one pictured looks a little different than the other 2 and sure looks like a vacuum port. Maybe there's just the one for vacuum petcocks and the other 2 are overflows?
The Kaw List:
