A really dumb petcock question
- giftofthegods77
13 Feb 2006 16:56
Newbie alert!
Okay, this may be a really dumb question. My intuition says it is. I need to rebuild the petcock on my 79 650 D2, and I was told I do not need to drain the gas tank before I do this. My guess is that as soon as I open up the petcock, I will end up draining the tank all over myself and my garage floor.
So, do I in fact need to drain tank, and if so, what's the best way to go about this.
- wireman
- hwms
Re: A really dumb petcock question
13 Feb 2006 17:48
giftofthegods77 wrote:
No, this is not a dumb question. Just simply inane.
Did you ever wonder what the petcock on the tank is for? Could it possibly be to control the flow of fuel?
To drain. Turn off fuel(petcock). Remove the fuel hose from the petcock. Attach a long hose to the petcock turn the fuel valve to "prime" and drain fuel into a container.
Newbie alert!
- giftofthegods77
14 Feb 2006 12:10
Thanks for the reply Hwms.
Does anyone out there know if I can use a 1979 KZ650 B petcock on my 79 KZ650D2? I can buy the rebuild kit for about $20, or I can buy a used petcock off ebay for about $8.00. Clearly, I would rather spend less money and I know rebuild kits may not solve my problem.
- OKC_Kent
14 Feb 2006 12:40
I will guess that most of us have at least tried to rebuild a petcock. I think most of us would say "don't waste the money". For $30 or so, you can buy a manual petcock, and adapter plate from Z1 Enterprisses or Dennis Kirk, etc etc.
I did all three,,,, bought a rebuild kit, then bought a used ebay deal, and finally bought a $30 new one. Guess which one works?
Cashion, OK
78 KZ650 B2 85,000+ miles
- RomSpaceKnight
14 Feb 2006 15:16
You could always run tank fairly empty then lay on side and allow fuel to sit in other side of tank. Of course the tank must be off bike.
