- Thank you received: 7
Whew
- austin3119
03 Sep 2008 17:32 - 03 Sep 2008 17:38 #235356
by austin3119
Whew was created by austin3119
My bike has been sitting in the garage for the past couple of months since it is our winter time here in Phoenix
I went out to start the bike yesterday and all the carbs were overflowing once started. Err. So I turned off the gas, started the bike again and tried to blow the crud out by reving the engine and occassionally turning the gas on. No luck. All carbs still leaking.
In a last ditch attempt before pulling the rack off to do a rebuild I decided to drop some Seafoam in the tank and try the reving procedure again. Apparently whatever I did yesterday worked and there was no need for the Seafoam. No leaks upon startup!
Better to be lucky than good sometimes.
Last edit: 03 Sep 2008 17:38 by austin3119.
- NickW900LTD
- Nick
03 Sep 2008 18:23 #235363
by NickW900LTD
1976 KZ900 LTD (sold)
1977 KZ1000 LTD
1978 KZ1000 A2A
Pierceton, Indiana USA
Replied by NickW900LTD on topic Whew
sometimes junk in the carbs will cause floats to stick.
1977 KZ1000 LTD
1978 KZ1000 A2A
- Bluemeanie
- Thank you received: 14
03 Sep 2008 20:40 #235384
by Bluemeanie
Replied by Bluemeanie on topic Whew
Normal thing to happen after sitting for awhile. You could have also gently tapped on the bowls also with good results.
- austin3119
03 Sep 2008 21:22 #235391
by austin3119
Replied by austin3119 on topic Whew
Good tip blue. Whenever I let the bike sit for a while I take out some screwdrivers and play those bowls like a musical instrument. For some reason it didn't do the trick..... Or maybe it did. I'm not sure at this point.
- bountyhunter
- Thank you received: 337
03 Sep 2008 21:29 #235395
by bountyhunter
Replied by bountyhunter on topic Whew
austin3119 wrote:
If gas is left in the bowls for months, it will turn into sticky varnish and make the floats stick. Seafoam will dissolve it, at least some of it.
