Need link to procedure to set float height BS34
- Exitpupil
28 Aug 2008 21:10 #234535
by Exitpupil
79 KZ1000 LTD B3, 1075 kit, BS34 carbs, high velocity ported heads, K410 cams, V&H pipe w/custom baffle
Need link to procedure to set float height BS34 was created by Exitpupil
I am tired of searching. How do I set the float height properly? I keep seeing clear hose referred to? Is there a link to a write up? Thanks1
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
- Thank you received: 3
28 Aug 2008 22:59 - 28 Aug 2008 23:01 #234539
by Skyman
West Linn, OR
Replied by Skyman on topic Need link to procedure to set float height BS34
I don't know where you would find a "write up", but the procedure is fairly simple, and I'll try to explain it for you. Take a length of 3/16" clear vinyl tubing about 12-16" long. If you like, you can take a fine tip Sharpie pen and mark two lines 3mm apart a couple inches from one end.
Put your bike on the center stand so that it is as level as possible.
Move your petcock to the "PRI" postion (if you have a vacuum petcock). Otherwise, turn it to "ON" if you have a manual petcock.
Attach the non-marked end of the hose to the drain nipple of a float bowl. Hold the marked end of the tube up against the side of the carb body, with the top mark even with the line where the bottom of the carb body and top of the float bowl meet.
With a screwdriver, open the drain screw at the bottom of the float bowl. This will allow gas to drain from the bowl and fill the tube up to the lower mark on the tube. If an air bubble gets trapped in the tube, flick it with your finger until the bubble clears--otherwise you will not get an accurate reading.
Have a gas can handy so that after taking the reading, you can close the drain screw and drain the gas into the can.
Repeat for each carb.
If the gas level is not within 1mm of the lower mark, then you need to adjust your float level. Switch your petcock back to the off position, then drain your float bowls. Remove the carbs from the bike, and remove the bowls of the carbs that need adustment. Remove the float assembly and carefully pry the adustment tang up or down, depending on if you need to raise or lower the level. Make SMALL adjustments. It doesn't take much movement to make a difference.
Reassemble and retest. Repeat until levels are in spec.
West Linn, OR
Last edit: 28 Aug 2008 23:01 by Skyman.
The following user(s) said Thank You: kzwill
- Exitpupil
29 Aug 2008 05:10 #234567
by Exitpupil
Replied by Exitpupil on topic Need link to procedure to set float height BS34
Skyman, Thank you very much for taking the time to explain it for me. What a great forum.
Will Piatt
Will Piatt
- JMKZHI
- Thank you received: 48
29 Aug 2008 07:26 - 04 Dec 2008 08:51 #234588
by JMKZHI
Replied by JMKZHI on topic .
del
Last edit: 04 Dec 2008 08:51 by JMKZHI.
- wiredgeorge
29 Aug 2008 07:34 #234593
by wiredgeorge
Replied by wiredgeorge on topic Need link to procedure to set float height BS34
The tang is the small metal square that contact the spring loaded pin in the float needle. Curious about how you flex a tang. I suspect that if the float level changed after you flexed it, you actually bent the thing. I would never recommend bending anything else on a float as it only mis-orients them making further adjustment even harder.
- JMKZHI
29 Aug 2008 08:26 - 04 Dec 2008 08:52 #234606
by JMKZHI
del
Last edit: 04 Dec 2008 08:52 by JMKZHI.
- OKC_Kent
- Thank you received: 20
29 Aug 2008 10:21 #234622
by OKC_Kent
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
Replied by OKC_Kent on topic Need link to procedure to set float height BS34
Oklahoma City, OK
- Stevec6535
29 Aug 2008 13:33 #234643
by Stevec6535
Replied by Stevec6535 on topic Need link to procedure to set float height BS34
Great info guys. Can this adjustment be done and tested on a work bench or does it have to be done on the Bike?
- Skyman
29 Aug 2008 15:45 - 29 Aug 2008 15:47 #234659
by Skyman
West Linn, OR
Stevec6535 wrote:
It can be done on a work bench. You just need to make sure the carbs are mounted to something stable (I use a bench vise with a towel to protect from scratching), and that they are level front to back and side to side. You then need to have a free-flowing fuel source situated somewhere higher than the carbs so that gravity can feed fuel into the carbs.
West Linn, OR
Last edit: 29 Aug 2008 15:47 by Skyman.
- wiredgeorge
29 Aug 2008 16:53 #234663
by wiredgeorge
I don't think it would be easy to do the procedure with the carbs on the bike. While they are fairly level, they are not exactly level. We put the carburetors in a carburetor holder and use a level to ensure the carbs are perfectly level.
If you put the carbs in a vise, and it is just fine to do so, I would be a little scared to use a towel. The towel will help protect the surface a bit from scratching but vise pads allow the pressure to be distributed. I have bent the intake venturi on carburetors in the past and never realized what caused it. That stopped when I started using vise pads. I have several sets I bought from Golfsmith, a golf clubmaking supply place and a couple other sets that are L shaped and hang over the jaws of the vise and have rubber pads. Both work well. I don't remember where I got the metal (with rubber) pads but it was probably a home improvement place or hardware.
