Leaking Float Bowl
- Stevec6535
26 Aug 2008 06:52 - 26 Aug 2008 10:21 #234031
by Stevec6535
Leaking Float Bowl was created by Stevec6535
Thanks to all of members of the forum who helped me out with my Air Fuel Mixture Screw questions that I had last week. now I have a new Carb related question. The Motorcycle I am working on is a 1981 KZ750 Four Cylinder H2. I've installed the (Kehin)Carb rebuild kit that I purchased from a Company recommended on this web site (Z1Enterprises). My question is, I have a small drip coming out of the over flow nipple on the bottom of the float bowl on the #2 Cylinder. My first thought is to pull the carbs back off and adjust (tweak) the floats on that carb only but I just wanted a couple of opinions before I take it back apart. Any advice would be greatly appreciated.
Thanks
Thanks
Last edit: 26 Aug 2008 10:21 by Stevec6535.
- Link14
- Thank you received: 6
26 Aug 2008 07:00 #234034
by Link14
Replied by Link14 on topic Leaking Float Boal
Hmmm, are you sure that's an overflow nipple? I've got a 1982 kz750-4 H3 with Keihin CV34 carbs. My carbs don't have overflow, the nipple is just a drain for the bowl. If you're getting a drip, maybe the new 0-ring didn't seat correctly.
- Sandy
- Fly High,Tony
- Thank you received: 13
26 Aug 2008 07:11 #234036
by Sandy
1977 KZ1000 A-1
Replied by Sandy on topic Leaking Float Boal
Are you SURE it's leaking from the nipple,and not the bowl gasket,or even the t-fitting(if you have one)?
Check around,higher than where you THINK it's leaking from,to be sure.
The leaking gas will form and drip at the low-point,but that may NOT be the source of the leak.I've been fooled before,so make sure it's not leaking from somewhere else.
Check in the higher regions of the carbs,and make sure the leak isn't travelling to where you think it's leaking from.
Wipe the bowls dry,and then use a q-tip to feel around...checking the q-tip periodically.
1977 KZ1000 A-1
- Stevec6535
26 Aug 2008 07:28 - 26 Aug 2008 10:20 #234040
by Stevec6535
Replied by Stevec6535 on topic Leaking Float Bowl
I watched it come form the Nipple. When I shut the fuel off (manual Petcock). It will drip about a tablespoon of fuel from that nipple only, over a period of a minute or two. Does anybody know if the copper tube running up the inside center of the float bowl is a over flow tube?
Last edit: 26 Aug 2008 10:20 by Stevec6535.
- Link14
26 Aug 2008 20:53 #234159
by Link14
Replied by Link14 on topic Leaking Float Bowl
Just checked my manual and it does show an overflow tube for the 1981 model....sorry I questioned it.
I'm thinking that you'll need to get in there and adjust the float, sorry I know that's a pain, I had to pull my carbs 4 times this Spring. It took a month for my knuckles to recover!
- Thank you received: 2098
26 Aug 2008 21:17 #234162
by Patton
Replied by Patton on topic Leaking Float Bowl
Stevec6535 wrote:
If some crud is preventing a complete seal where pointed end of float needle fits against its seat, fuel can continue flowing into the floatbowl past the incomplete seal and on out the overflow.
Sometimes any such crud may be flushed away by opening the floatbowl drain screw, and allowing fuel to keep flowing through for a few moments in hopes of flushing away the crud.
Good Luck!
... have a small drip coming out of the over flow nipple on the bottom of the float bowl...
Good Luck!
- wiredgeorge
27 Aug 2008 04:52 #234194
by wiredgeorge
Replied by wiredgeorge on topic Leaking Float Bowl
Some CV34 assemblies have brass tubes (overflows) and some don't. They connect to the drain. If the tube isn't cracked, the float height or valve needle/seat may be the issue. On the CV34, you can't change the seat so it needs to be cleaned. Last, if the oring on the drain screw is bad or the drain screw is worn (they often are), the drain will leak. Swap the drain screw from the leaking carburetor with one from a carburetor that isn't leaking to eliminate this as an issue.
- Stevec6535
29 Aug 2008 13:37 #234644
by Stevec6535
I've got a extra set of carbs. I will swap out the float bowl and give it a try when I rejet.
Thanks
Thanks
