Jetting advise needed
- jcote75
Would need some help here.
I was running my KZ1100R with the stock 4/2 exhaust and stock airbox. Was running fine.
I've install a 4/1 Kerker KR with the 2.5" competition baffle and now I have some miss after 6,000 rpm. By the way, that baffle is very very loud!
I've just order a 2" baffle which should less loud and will arrived in a few weeks.
I have also a set of Emgo pods that will be installing shortly to complete the set up.
So, with the pods + Kerker 2", which jet size should I get to resolve the problem at high revs?
In the mean time, can I ride the bike beeing carefull not to go over 6,000 rpm?
Thanks in advance,
Joce
- Royal1MC
- Is it just me, or is it just great to be on a KZ
Not sure which carbs you're running but here's a link for Mikuni carbs:
www.motorcyclecarbs.com/Motorcycle_Carburetor_Jetting__W7.cfm
*1980 Z1-R (current))
*1978 KZ1000 LTD w/ Z1-R frnt end (sold)
*1977 KZ650 B1 (sold)
Los Angeles, CA
- bountyhunter
- Thank you received: 337
Hi,
Thanks in advance,
Joce
I vote for being careful since you are probably running too lean now. Install the pods and you will probably be MUCH too lean and it won't run worth crap. BTW, running lean can be dangerous because of burning pistons.
- OKC_Kent
- Thank you received: 20
Hi,
Thanks in advance,
Joce
Check this link out, it's a guideline.
kzrider.com/index.php?option=com_docman&...d&gid=212&Itemid=108
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
- wiredgeorge
