syncronizing carbs
- jtsbh
22 Aug 2008 15:37 #233512
by jtsbh
syncronizing carbs was created by jtsbh
I am getting ready to do a tune up on the bike I am buying. I was reading in the Clymer manual about syncronizing the carbs and there are two different sections. One is for vacuum adjust and the other is for mechanical adjustment. my bike is a 78 kz 1000 and I plan to take the carbs apart and clean them. what is the difference and which will I need to do? And does it vary by year?
- Thank you received: 2098
22 Aug 2008 16:07 #233516
by Patton
Replied by Patton on topic syncronizing carbs
jtsbh wrote:
Hi, Jordan! The mechanical adjustment refers to a bench synch attempting to attain the closest physical match among throttle slide positions with carbs removed from the bike. The vacuum synch is done later with the engine running by using a manometer connected to the vacuum nipples on the carb holders, to match the actual vacuum performance among the carbs on the running engine.
Good Luck!
Good Luck!
- 05c50
22 Aug 2008 16:15 #233517
by 05c50
\'79 KZ200
\'75 GL1000
\'77 CB550F
\'77 CB750A
\'78 GL1000
\'80 CB650C
Replied by 05c50 on topic syncronizing carbs
Syncronizing the carbs using the "Vacuum" method will allow adjustments to be made for small differences in the cylinders effiencies. For example, if one cylinder has slightly less vacuum due to worn rings, the carb will be adjusted to attempt to make all cylinders even. If you're going to disassemble the carbs. you need to do a "mechanical" adjustment when you reassemble,as a starting point.
Hope this helps.
.....Paul
Hope this helps.
.....Paul
\'79 KZ200
\'75 GL1000
\'77 CB550F
\'77 CB750A
\'78 GL1000
\'80 CB650C
