Chemical used in heated sonic cleaner?
- lx460
2001 KZ1000P
1986 KZ1000P
1981 KZ1000LTD
1980 KZ1000
1988 KZ1000P
See a pattern?
- MFolks
- Thank you received: 540
I'm not sure what is being used know but if you google Branson ultasonic cleaners the information should be found.
- steell
Check this out:
1,1,1-TRICHLOROETHANE
PHYSICAL STATE; APPEARANCE:
COLOURLESS LIQUID , WITH CHARACTERISTIC ODOUR.
PHYSICAL DANGERS:
The vapour is heavier than air.
CHEMICAL DANGERS:
The substance decomposes on heating or on burning producing toxic and corrosive fumes including phosgene and hydrogen chloride. Reacts violently with aluminium, manganese and their alloys, alkalis, strong oxidants, acetone and zinc. Attacks natural rubber. Mixtures of 1,1,1-trichloroethane with potassium or its alloys are shock sensitive. Reacts slowly with water releasing corrosive hydrochloric acid.
OCCUPATIONAL EXPOSURE LIMITS (OELs):
TLV: 350 ppm; 1910 mg/m3 (as TWA); 450 ppm; 2460 mg/m3 (as STEL) (ACGIH 1994-1995).
ROUTES OF EXPOSURE:
The substance can be absorbed into the body by inhalation of its vapour and by ingestion.
INHALATION RISK:
A harmful contamination of the air can be reached rather quickly on evaporation of this substance at 20�C.
EFFECTS OF SHORT-TERM EXPOSURE:
The substance irritates the eyes, the skin and the respiratory tract. The substance may cause effects on the heart and central nervous system, kidneys and liver , resulting in cardiac disorders and respiratory failure. Exposure at high level may result in death. Medical observation is indicated.
EFFECTS OF LONG-TERM OR REPEATED EXPOSURE:
The liquid defats the skin. The substance may have effects on the liver.
LINK
- MFolks
- lx460
2001 KZ1000P
1986 KZ1000P
1981 KZ1000LTD
1980 KZ1000
1988 KZ1000P
See a pattern?
- SPARKY47
- 1980 KZ500 B2
Check out the flashpoint of the stuff verses the temp...
1980 KZ500 B2
- fixer5000
1978 kz650b pretty much stock
massachusetts
