Gasket/oring question
- coppertales
08 Aug 2008 07:06 #230820
by coppertales
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
Gasket/oring question was created by coppertales
On my 1982 1100A2, the air screw orings (square rings?) are hard and no longer hold the screws in place. Engine vibration moves them in/out. Yes, the springs are in place. Where can I get replacement orings without buying the whole rebuild kit? The bike runs good otherwise. Thanks...chris3
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
- Sandy
- Fly High,Tony
- Thank you received: 13
08 Aug 2008 07:23 - 08 Aug 2008 07:42 #230823
by Sandy
1977 KZ1000 A-1
Replied by Sandy on topic Gasket/oring question
I remember a long time ago,I needed an o-ring similar to those ones,Chris,and they are what I was told,a "Quad-ring",hence the 4 sides.
Check with places that deal with natural gas or propane.They use o-rings like that in a lot of fittings.I don't remember if I was successful in finding them or not,or if they handle smaller ones,like you need.
Here's some links for you to look at...
LINKS
LINKS
1977 KZ1000 A-1
Last edit: 08 Aug 2008 07:42 by Sandy.
- harm
- Tom
08 Aug 2008 08:58 #230834
by harm
Tom
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
Replied by harm on topic Gasket/oring question
You may try
www.mcmaster.com
Tom
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
- RonKZ650
- Thank you received: 240
08 Aug 2008 10:06 #230844
by RonKZ650
Replied by RonKZ650 on topic Gasket/oring question
If you're just talking the oring that goes on the air screws, those are probably stock at any dealer as they used the same ring for 20+ years 16038-022
- coppertales
08 Aug 2008 11:14 #230859
by coppertales
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
Replied by coppertales on topic Gasket/oring question
Thanks guys....the dealer here has morons on the parts desk. You walk in there with an IPC from the Kaw web site and they look at you like "what are you, some kinda of smart ass?". I told one guy that I was riding my Z1 when he was still a figment of his daddy's imanigation. It is Friday and I need a little humor....chris3
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
