Fuel/Air mixture problem
- MikeHoncho
06 Aug 2008 10:04 - 06 Aug 2008 10:06 #230509
by MikeHoncho
1980 kz440
Fuel/Air mixture problem was created by MikeHoncho
1980 kz440
I've been having trouble getting the right fuel mixture to my carbs. I just recently got the float levels correct (thanks bountyhunter) but the bike still doesn't want to get going above 4K RPMs. It also wants to stall when i come to a stop unless I give it a little throttle. I noticed in the left carb that it is missing the little plastic plug that covers the pilot jet. What is that for? Would that be causing me any problems? I have already made sure all of the passageways in the carbs are clear and checked the petcock to see if it works. It works great in prime. I'm not sure how to check if the vacuum is working. Any other suggestions??
1980 kz440
Last edit: 06 Aug 2008 10:06 by MikeHoncho.
- bountyhunter
- Thank you received: 337
06 Aug 2008 12:12 #230533
by bountyhunter
Replied by bountyhunter on topic Fuel/Air mixture problem
Paging Dr. Wiredgeorge........
I'm not sure about that, Wiredgeorge is the resident carburetor expert.
- anarki650
- Thank you received: 5
06 Aug 2008 12:48 #230542
by anarki650
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
Replied by anarki650 on topic Fuel/Air mixture problem
Flip your petcock over to prime and take it for a short ride. If the problems go away you know your issue is caused by poor fuel delivery, easy 'nuff.
09 Kawasaki ER6n
Omaha NE
- MikeHoncho
06 Aug 2008 15:34 #230559
by MikeHoncho
1980 kz440
Replied by MikeHoncho on topic Fuel/Air mixture problem
Thanks for the advice anarki650. That was actually my next plan of attack. I'm just hesitant to put the carbs back on the bike till I know what the plastic plugs are for. I don't want to have to pull them off again just to replace that. Anybody know?
1980 kz440
- KZQ
- Administrator
- Thank you received: 1415
06 Aug 2008 18:42 - 06 Aug 2008 18:49 #230579
by KZQ
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Replied by KZQ on topic Fuel/Air mixture problem
Hi Mike,
Those plastic plugs are required by the Govnmn't because they've learned that if you can't see a problem it doesn't exist. Their reasoning is that if the owner doesn't know that the idle mixture can be adjusted, it won't be.
If one of your idle screw covers is missing it's no big deal.
"I have already made sure all of the passageways in the carbs are clear..."
If one of your carbs still has it's cover on the pilot screw, you haven't yet checked all the passages.
What do your spark plugs look like?
KZCSI
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Last edit: 06 Aug 2008 18:49 by KZQ.
- wiredgeorge
07 Aug 2008 06:08 #230630
by wiredgeorge
Replied by wiredgeorge on topic Fuel/Air mixture problem
Lord! Free advice is worth every cent bwhahahaha BILL! The plugs over the pilot jets are to keep gas from entering the pilot jet well and FLOODING the pilot jet. Gas gets to the pilot jet via a cross passageway from the main jet well. The bike won't run right till a new plug is secured and installed. I know you can get them. Get the Kaw part number and call Z1Enterprises.com and order one.
- MikeHoncho
07 Aug 2008 15:16 - 07 Aug 2008 15:17 #230702
by MikeHoncho
1980 kz440
Thanks so much for the info wiredgeorge. I figured it might have something to do with my problems.
1980 kz440
Last edit: 07 Aug 2008 15:17 by MikeHoncho.
- wiredgeorge
08 Aug 2008 06:12 #230813
by wiredgeorge
The plug has an oring and is made of white plastic that turns reddish brown over time. I am not really sure if you could use a Suzuki style plug which is just a black rubber cork essentially. The main thing would be the installed height because there is a nub cast into the bowl that pushes down on the the plug to keep it in place. If the rubber plug was shorter, the nub wouldn't reach it and it would eventually leak gas without having a mechanical keeper method. Plugging the pilot well is a fairly common practice. You can see a cross passage but another easy way to tell if your carb has this feature is to remove the pilot and main jets and spray carb cleaner in the pilot air jet located on the venturi edge. If it needs a plug, gas will come out both the pilot and main jet wells.
- KZQ
- Administrator
08 Aug 2008 07:34 #230826
by KZQ
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Sorry Mike, You did say "pilot jet" didn't you.
Thanks for the correct info WG.
KZCSI
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
