fuel line size
- jus1975
- www.tripleaperformance.com
02 Aug 2008 22:23 #229802
by jus1975
fuel line size was created by jus1975
I'm putting my Z1 back together and I do not know what size the fuel line and vent lines are. Does 5/16 and 1/4 sound right.
- wiredgeorge
03 Aug 2008 04:29 #229814
by wiredgeorge
Replied by wiredgeorge on topic fuel line size
1/4" is fine. If you use 5/16" make sure you use good clamps as the line will be a bit loose on the fuel fittings on the carbs but 5/16" will work as well.
- jus1975
03 Aug 2008 09:44 #229856
by jus1975
Replied by jus1975 on topic fuel line size
Thanks, I'll give it a shot. I'm trying out the Z1 carbs I got back from you this weekend.
