- Thank you received: 16
Leaking fuel tubes between 73 - Z1 28mm carbs
- mtkawboy
02 Aug 2008 09:43 #229682
by mtkawboy
Leaking fuel tubes between 73 - Z1 28mm carbs was created by mtkawboy
Anyone had any luck stopping leakage at the fuel tubes between carbs without a total major overhaul ? Bike is a 73 Z1 w/stock 28mm VM carbs but same deal on all of the Z1/KZ900/KZ1000 carbs I think. I have 2 73 sets and 1 75 and they all leak. Will trade even one set for good set of leak free running 26mm carbs, prefer 76 KZ900's
- Thank you received: 2098
02 Aug 2008 10:49 #229697
by Patton
Replied by Patton on topic Leaking fuel tubes between 73 - Z1 28mm carbs
If the fuel pipes are loose and leaking, Z1E has them.
Z1 fuel pipe .
Some folks report success by wrapping the old joints with teflon tape which tightens the fitment.
Good Luck!
Z1 fuel pipe .
Good Luck!
- mtkawboy
02 Aug 2008 16:19 #229749
by mtkawboy
Replied by mtkawboy on topic Leaking fuel tubes between 73 - Z1 28mm carbs
Thanks, I didnt know they were available. Sounds like either way the carbs have to come apart. Do they just press in or is there an o-ring or something ?
- Sandy
- Fly High,Tony
- Thank you received: 13
02 Aug 2008 16:45 #229763
by Sandy
1977 KZ1000 A-1
Replied by Sandy on topic Leaking fuel tubes between 73 - Z1 28mm carbs
Not 100% sure,but they will either have o-rings,or they will have a rubber coating on them.(with ribs formed into the metal casting)
I've seen both,and have dealt with both...can't say for sure on the carbs you have though.
I did the teflon-tape trick,and it did work.(3 plus years)
For peace of mind though...get new ones from Jeff and call it done.
1977 KZ1000 A-1
