i think I have figured my problem out
- 82_gpz_550
31 Jul 2008 07:36 #229337
by 82_gpz_550
82 KZ550 H1 (GPz) \'Lil Red
it\'s an old beater, but when she wants to
she sure runs great!
i think I have figured my problem out was created by 82_gpz_550
started her up yesterday and after it started running it was dripping gas big time from the #1 carb, so yeah gonna order some rebuild kits in a bit, how tough a job is it to do?
- bill_wilcox100
- Thank you received: 5
31 Jul 2008 08:08 - 31 Jul 2008 08:09 #229351
by bill_wilcox100
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Replied by bill_wilcox100 on topic i think I have figured my problem out
Not knowing what bike we are talking about, the usual causes of these symptoms are:
No or poor inline gas filter causing carb float bowl valve to not fully close when bowl is full.
Typical solutions include:
1) Add/replace inline fuel filter.
2) Tape float bowl to dislodge obstruction in float bowl valve... if no change then drain and remove bowl and clean valve and valve seat... add/replace gas filter and flush fuel line.
3) If the above does not work, be prepared to remove and clean out the carb.
Best of success.
BTW, could you add your year, model and location to your signature for the best replies.
Best of success.
Upgrades:
Montreal, Canada
Last edit: 31 Jul 2008 08:09 by bill_wilcox100.
- 82_gpz_550
01 Aug 2008 01:10 #229499
by 82_gpz_550
Replied by 82_gpz_550 on topic i think I have figured my problem out
oh sorry, i could have sworn i changed my sig
but yeah my bike is an 82 GPZ550/KZ550 H1
i just went out and took it around the parking lot
this time it was barely dripping at all
so I think it's definitely a carb issue
and from what I'm been reading on carbs
I believe it's float needle or something like that
tomorrow I'm going to drain all the bowls and put a bottle of carb cleaner in the tank, and maybe run the hell out of it for a bit or maybe that's a bad idea. If anyone has any input I'd be grateful to hear it!
thanks again
thanks again
- bill_wilcox100
01 Aug 2008 07:16 #229529
by bill_wilcox100
Upgrades:
Montreal, Canada
If there is something preventing the needle valve for seating properly it may or may not be soluble with carb cleaner.
If carb cleaner does not work, be prepared to:
1) remove the float bowl from the offending carb,
2) remove the float,
3) remove/inspect/clean/replace the needle valve and,
4) remove/inspect/clean/replace the needle valve seat.
Best of success.
PS
Don't worry if you didn't get the signature the first time. It can be a pain... keep trying.
Best of success.
PS
Upgrades:
Montreal, Canada
- 82_gpz_550
01 Aug 2008 17:48 #229604
by 82_gpz_550
ok well my friend's dad made the suggestion to try seafoam
he swears by it been using it for ages, so I'm gonna try that out next and hopefully that will clean things up a abit
- Saki Jockey
01 Aug 2008 18:17 #229610
by Saki Jockey
Rob A.
550 A4
GTA,
Ontario, Canada
Replied by Saki Jockey on topic i think I have figured my problem out
check out
Rob A.
550 A4
GTA,
Ontario, Canada
- 82_gpz_550
01 Aug 2008 20:03 #229620
by 82_gpz_550
I'm not wanting to put it through the vacuum system.
right now I'm almost on E so I'm gonna put a few ounces in the tank and run it through that way, OR
does any one think it might be a better idea for me to use a regular bottle of gas additive carb cleaner first run that through after draining the float bowls then let it sit a day with the cleaner in the bowls and then fun the seafoam. or am I way off base with this idea?
- anarki650
01 Aug 2008 20:45 #229630
by anarki650
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
Replied by anarki650 on topic i think I have figured my problem out
Have you verified correct float height? If your float is set too high you're going to piss gas until it's corrected, regardless of how clean, dirty, or deformed your float needle and seat are. If the float height is correct and you're still not getting a good seal on the needle it could be a piece of crap stuck between the needle (that may or may not be disolved by a pour in cleaner), it could also be a cracked overflow tube. I just ran into a cracked tube a couple months back and I was going nuts trying to figure out why that carb kept pissing fuel like it did.
09 Kawasaki ER6n
Omaha NE
- 82_gpz_550
02 Aug 2008 07:26 #229657
by 82_gpz_550
see that's why i think the need is stuck ,cause it had been sitting for a couple of weeks then I started it up
and it ran fine but then started leaking while running.
but then the next day started up again and no leaking
so I would assume it was gunk or varnish. i don't think
the floats are effed, because it ran great for a year, then I admit I have just been too busy and it sat for a month or 2.
- bill_wilcox100
02 Aug 2008 09:19 - 02 Aug 2008 09:20 #229678
by bill_wilcox100
Upgrades:
Montreal, Canada
Remember, if it is only the needle valve assembly that is the problem you don't need a full carb rebuild kit. All you need it the "Float Needle Valve Assembly Kawasaki KZ550 ZX550". See here:
www.z1enterprises.com/detail.aspx?ID=2559
At under $10 USD plus shipping it’s the most economical way to go, IMHO.
The complete "Carburetor Rebuild Kit KZ550 ZX550 (82-85)"
is under $20 USD plus shipping and that's your call. See here:
www.z1enterprises.com/detail.aspx?ID=2028
If your rubber seal is bad this may be the way to go.
Best of success.
Best of success.
Upgrades:
Montreal, Canada
Last edit: 02 Aug 2008 09:20 by bill_wilcox100.
- 82_gpz_550
02 Aug 2008 19:38 #229785
by 82_gpz_550
just went out for a ride and no leaking
WOOHOO, I'm hoping this will keep working as long as I do not neglect it anymore, yeah I'm thinking of going with the 20$ kits just do it all at once.
