Cold Blooded 1980 KZ1000 Shaft
- brad21
- '80 KZ1000 Shaft
01 Aug 2008 07:27 #229530
by brad21
\'80 KZ1000 Shaft
Replied by brad21 on topic Cold Blooded 1980 KZ1000 Shaft
Thanks guys. I know the carbs need a good cleaning but I'm not quite prepared to tackle that myself at the moment. I have used almost a full can of Seafoam and have the air screws at 1.5 out.
\'80 KZ1000 Shaft
- Thank you received: 2098
01 Aug 2008 08:53 #229549
by Patton
Replied by Patton on topic Cold Blooded 1980 KZ1000 Shaft
brad21 wrote:
Perhaps allowing too much air and therefore excessively lean. Would screw in 1/4 turn to 1.25 out and re-test.
Good Luck!
... air screws at 1.5 out.
Good Luck!
- wiredgeorge
03 Aug 2008 04:50 #229815
by wiredgeorge
Replied by wiredgeorge on topic Cold Blooded 1980 KZ1000 Shaft
The pilot and enrichener circuits need cleaning. Mikuni VM series carbs are not particularly cold blooded... problem is, most folks who say this have never cleaned their carburetors properly or have modified something that causes them to be lean at start up.
