Idle Problems, please help!
- BLR_STS
29 Jul 2008 10:16 #228899
by BLR_STS
1981 KZ 750
Idle Problems, please help! was created by BLR_STS
Hey guys,
I am new to these boards, but have been snooping around and found them a valuable resource. I have a 1981 KZ 750-E. and it is idling a tad bit low, just enough to die on me at stops. Is there any was to adjust the carbs so it will idle just a tad bit higher. If someone could tell what I need to turn and where it is located that would be tremendous.
TIA
-Josh
TIA
-Josh
1981 KZ 750
- KOOL RYDER
- KZ 650B2 / KZ 1000E
29 Jul 2008 10:27 #228903
by KOOL RYDER
Rockin\' a KZ650B2 since 2007 and a KZ 1000E since 2008
1978 KZ650B
1979 KZ1000ST
Replied by KOOL RYDER on topic Idle Problems, please help!
Is there not a master idle screw on those bikes?
Look at the carbs and there should be a master screw in the center above the carbs.
Turn this knob / screw to the right (clockwise) to increase the RPM's or left (CCW) to decrease the RPM's.
I have found that when cold the bike will run at higher rpm's then after it has warmed up a bit.
A slight adjustment 1/4 turn will affect the RPM's, just turn it a bit, then wait 10 - 15 seconds to see the rpm tach respond. (it may require more , just take it a bit at a time)
I adjust my idle screw every few weeks as it seems to always be needed if the weather is hot and dry or damp and humid.
Hope this helps.
Hope this helps.
1978 KZ650B
1979 KZ1000ST
