Hoses Hanging Around
- AndrewT
28 Jul 2008 18:02 #228790
by AndrewT
Hoses Hanging Around was created by AndrewT
Ok, I put the carbs back on my bike, and I have four hoses hanging down from the bottom of the carbs, and I have one clear largish diameter on the far right side, top of the carb (as in, if you're sitting on the bike, it'd be right by your right knee). I have the gas tank hooked up to the carbs with the hoses from the petcock, so whats the deal with these other ones??
Is there an install guide someone can point me out to?
- Sandy
- Fly High,Tony
- Thank you received: 13
28 Jul 2008 18:18 #228793
by Sandy
1977 KZ1000 A-1
Replied by Sandy on topic Hoses Hanging Around
The 4 hoses on the bottom are overflow lines.
Can you post a picture of the set-up,and also...what bike are we talking about here?...
1977 KZ1000 A-1
- Royal1MC
- Is it just me, or is it just great to be on a KZ
28 Jul 2008 18:28 #228794
by Royal1MC
*1980 Z1-R (current))
*1978 KZ1000 LTD w/ Z1-R frnt end (sold)
*1977 KZ650 B1 (sold)
Los Angeles, CA
Replied by Royal1MC on topic Hoses Hanging Around
Might possibly a vacuum hose? You need to provide more info on the bike. Also are these stock carbs?
Los Angeles, CA
- The Milkman
- Thank you received: 194
28 Jul 2008 20:51 #228817
by The Milkman
Replied by The Milkman on topic Hoses Hanging Around
Sandy wrote:
I agree if the hoses are coming off the very bottom of the bowls they are overflow lines. I don't know if you still have it or not but on my 650 there is a rubber loop on the right side of the frame just behind the engine that they pass through as they hang over the rear of the engine.
- Thank you received: 2098
29 Jul 2008 02:23 #228853
by Patton
Replied by Patton on topic Hoses Hanging Around
AndrewT wrote:
Might be from one of the two vent nipples.
Check wiredgeorge's site for hookup info.
... one clear largish diameter on the far right side, top of the carb?....
- BeeSting
- Drive it like your tax dollars already paid for it
29 Jul 2008 06:34 #228862
by BeeSting
BeeSting
Flint, Michigan - Chicagoland, IL
If I wasnt such a badass American, I would have to drive a Harley to make up for it
1980 Kawasaki KZ750 H1 LTD (4)
Kurayami (Girl of Darkness)æš—é—‡ã®å¥³
1980 Honda CX500C - GONE
Christine
Replied by BeeSting on topic Hoses Hanging Around
I believe the hoses from the far left and far right (side, top) are vacuum hoses. On a stock setup they would be connected at a T and then routed into a larger pipe going forward under the tank and back into the airbox. I have mine going directly into the top/front part of the airbox.
The hoses coming out below the carbs would go into the friendly ports under the airbox.
I live in Flint, MI, and believe me, there's lots of hoes hanging around here, too.
BeeSting
Christine
