No Air fIlters in stock air box
- Cowasocky767
27 Jul 2008 20:42 - 27 Jul 2008 20:56 #228621
by Cowasocky767
No Air fIlters in stock air box was created by Cowasocky767
I just got my 1979 kz1000 ST shafty I plan on rebuilding the carbs and having them balanced. I noticed there was no air cleaners in the stock air box. How would this effect how the bike acts besides the fact its letting all the dirt and grime in of course? The bike starts right up right now but is boggy and backfires when you rev it up. It sounds like its running on all four but will check the plugs ASAP. I know I need to start widdling down allot of factors. The bike is breathing thru the air box, would installing air cleaners make it act any different?
Thanks for your help I'm just getting started on this project. I'm looking forward to diving in and seeing how this baby ticks! Any sujjestions on repair manuals?
Last edit: 27 Jul 2008 20:56 by Cowasocky767.
- Bluemeanie
- Thank you received: 14
27 Jul 2008 20:57 #228622
by Bluemeanie
Replied by Bluemeanie on topic No Air fIlters in stock air box
You need an air filter in that box, to clean the air and it will of course restrict slightly the amount of air entering the carbs. Don't think it will make much difference though with your problems.
- brad21
- '80 KZ1000 Shaft
29 Jul 2008 07:41 #228875
by brad21
\'80 KZ1000 Shaft
Replied by brad21 on topic No Air fIlters in stock air box
Mine's got a K&N shoved down in that slot. Definitely need to use some kind of filter.
\'80 KZ1000 Shaft
- cafekz750
29 Jul 2008 10:51 #228910
by cafekz750
1981 KZ750H2 - V&H 4-1 pipe, pods, jetted, clubmans, homebrew rearsets, 18" rear wheel and more.
Parting out a 1982 KZ750H3 to fund future projects
2 other non-Kawasaki motorcycles
Replied by cafekz750 on topic No Air fIlters in stock air box
Just more info.
On my 750, if I remove the air filter when running at idle (~1100rpm), the bike will idle up due to leaning the mixture out. You want an air filter in there before adjusting the carbs. Good luck.
