Don't really know !! carbs (i think)
- triggerbilly
27 Jul 2008 14:44 #228554
by triggerbilly
1982 kz750-e3
1983 cb1000c
plano. TX
Don't really know !! carbs (i think) was created by triggerbilly
I thought my bike was ony running on #2 and #3 cylinders
SO i tried changing the coils round
(just the two wires that connect onto each coil) (that's right ain't it ???)
Wouldn't start, got some REALLY BIG backfires though !!
so i put them back how they were.
I then took plug #1 out to check spark (fine)
same with #4 (spark fine)
i then took #2 plug out, spark fine
Left #2 out and also took #3 out and started it up ......... with # 1 and 4 in
The bike started but wouldn't idle very well, so i put all plugs back in and left the wires off plugs #2,3 Same result, the bike starts up but doesn't tick over well and only revs to about 3000rpm
So this means cylinders 1 and 4 must be firing (doesn't it ????)
which makes me think this is a carb/fuel problem
any thoughts ? PLEASE !!!!!!
apart from the obvious.....I HAVE TOO MANY CYLINDERS ON MY BIKE !!!!
1982 kz750-e3
1983 cb1000c
plano. TX
- FastKaw1
27 Jul 2008 15:11 #228564
by FastKaw1
Replied by FastKaw1 on topic Don't really know !! carbs (i think)
I would bet carbs.
Or gas related. How old is the gas? Has the bike bin sitting?
Are the intake boots good? No cracks and tight.
If you have spark on 1+4-2+3 most likely carbs/gas
- triggerbilly
27 Jul 2008 15:21 #228568
by triggerbilly
1982 kz750-e3
1983 cb1000c
plano. TX
Replied by triggerbilly on topic Don't really know !! carbs (i think)
the gas is new
the bike has been sat for a short time .. 20 YEARS !!!
but i've cleaned the carbs twice, fuel lines, put inline filters on, oil change new filter etc.
the boots/manifold are good i've done the wd40 squirt test and no change in rpm
i'm thinking the carbs may need a another real good clean
i'm just after some more ideas other than carbs
thanks
thanks
1982 kz750-e3
1983 cb1000c
plano. TX
- MFolks
- Thank you received: 540
27 Jul 2008 19:26 #228602
by MFolks
Replied by MFolks on topic Don't really know !! carbs (i think)
what is the condition of the fuel tank? Rust can get into the fuel system and plug up jets and cause the bike to run rough. A suggestion would be to find out who in your area can seal the fuel tank for you.
- anarki650
27 Jul 2008 20:03 #228611
by anarki650
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
Replied by anarki650 on topic Don't really know !! carbs (i think)
Did you replace the jets when you cleaned the carbs? Did you make sure the jet passages were clear? (spray carb cleaner into the jet opening and it should shoot out of the little hole in the front of the carb) If you're SURE it's not spark related (which I'd look at again since the 2/3 cylinders aren't firing and happen to share a coil) my best guess would be plugged jets or jet passages.
09 Kawasaki ER6n
Omaha NE
