carb still leaking
- jim_palmore
24 Jul 2008 21:52 #228175
by jim_palmore
ENJOY LIFE,, THIS IS NOT A DRESS REHEARSAL.
1991 KZ1000P FROM COPPER TO CHOPPER. MY BADASS BOBBER
carb still leaking was created by jim_palmore
I just finished (or so I thought) going through my carbs.. should have sent them to wiredgeorge.. anyway they won't stop leaking .I set the float at 19mm and put in new float valves, it still leaks and the pisser is that its not allways the same one.. sometimes its #1 and other times its #3.
a friend pointed out that since the petcock will not shut off the flow that that was the problem. so I put a valve inline between the petcock and the carbs to stop the flow.I think that the float are set too low because when I'm on the freeway it seems like its running out of fuel. but when I shut it off it leaks.
it also surges on the freeway but I think thats because of gusts and side drafts.
so here are the questions
1) is it normal / acceptable for the carbs to leak if the petcock is not working..
2) when I got the float valves they came with the seats also. should I change the seats? if thats not a factor I'd rather not do that..
3)I set the slides with a manometer but how do I set the air fuel mixture?? I think that that may be a factor also.
I don't want to set them too lean and burn a piston or too rich and foul a plug..
to all those who said not to go to pods back when I was first starting this mess. YES I SHOULD HAVE LISTENED..
anyone thinking of going to pods I tell you what I learned the hard way.. its a huge pain in the ass
I got some clear plastic tubing to check the float levels this weekend
- JMKZHI
- Thank you received: 48
25 Jul 2008 06:38 - 04 Dec 2008 07:14 #228232
by JMKZHI
Replied by JMKZHI on topic .
del
Last edit: 04 Dec 2008 07:14 by JMKZHI.
- KOOL RYDER
- KZ 650B2 / KZ 1000E
25 Jul 2008 08:36 #228248
by KOOL RYDER
Rockin\' a KZ650B2 since 2007 and a KZ 1000E since 2008
1978 KZ650B
1979 KZ1000ST
Replied by KOOL RYDER on topic carb still leaking
The last time this happened to me I just grabbed a piece of wood and a hammer after trying everything else and just placed the wood on the upper carb housing and whacked it hard 3 or 4 times and guess what, problem solved.
I have been riding the bike for a month now with no problems at all.
Get an inline fuel fiter and install it so the gunk wont get to the carbs.
Make sure the air filter is clean.
I know that this method sounds insane, but I have used it now on #4 carb last year and #2 carb a month ago..
Pretty cheap fix.
Pretty cheap fix.
1978 KZ650B
1979 KZ1000ST
- anarki650
- Thank you received: 5
25 Jul 2008 11:49 #228295
by anarki650
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
Replied by anarki650 on topic carb still leaking
Probably should have put in the new needle seats along with the needles. Both those parts wear and most likely wear into one another. Kinda like when you put new brake pads on a worn rotor without turning the rotor, the surfaces don't quite sit flush and you frequently get brake squeel out of brand new pads. If the needles and seats were in those carbs for years and wore together the odds that your new, perfectly machined float needles are finding the old seats to be not quite a perfect fit, allowing gas to pass through where it shouldn't be able to.
09 Kawasaki ER6n
Omaha NE
- jim_palmore
25 Jul 2008 19:45 #228368
by jim_palmore
Replied by jim_palmore on topic carb still leaking
I tilted them at a 30degree angle like the book said to.
as far as doing the seats whats the best way to remove them?just use vice grips??
- jim_palmore
25 Jul 2008 19:59 #228373
by jim_palmore
I would just rebuild the petcock but the kit is about75bux. I can make a flange and valve substitute for the petcock for alot cheaper. no reserve so I have to pay attention to that..
I plan on getting it going and selling it the seat is too far foward for my long legs.
gonna get a stock kz1000p and not modify it. damn sure gonna leave the freaking airbox on...
any buyers ????
I'm in it 2500 but will sell it for 2k
any buyers ????
- jim_palmore
26 Jul 2008 17:39 - 26 Jul 2008 23:44 #228453
by jim_palmore
changed the seats and still have one that really leaks bad.
the seats were totally different then the ones that were in it, but the old seats were ruined in the removal process (no easy task)
my leak is gushing out the mouth(breather side) where that little hole is thats above the float. is the float not seating or is there another cause for the overflow,is the new seat allowing fuel to bypass it??. I did the clear plastic hose to measure fluid level and it appears that the bowl is only half full.. I'm gonna try an old float in its place tomorrow. got too hot out there today
update
:blush: that little hole is not supposed to be there. I poked through when I took the old seat out.. patched it with jb weld and will try setting the floats tomorrow:S
update
Last edit: 26 Jul 2008 23:44 by jim_palmore.
- KOOL RYDER
29 Jul 2008 13:09 #228950
by KOOL RYDER
1978 KZ650B
1979 KZ1000ST
If that doesnt work, whack it with a piece of soft wood and a hammer.
I am telling you that it works.
You can pull the carbs a million times and not have the problem fixed.
I still cant believe it works as well as it does.
Wiredgeorge might want to hit me with a piece of wood and a hammer for suggestig it.
No, really I know sever people who have solved this problem like this.
Before you do it, drain the bowls and cross you fingers.
I hate it when it happens because it usually stinks out the garage or burns up the grass on the side of my house.
1978 KZ650B
1979 KZ1000ST
- anarki650
29 Jul 2008 13:29 #228953
by anarki650
09 Kawasaki ER6n
Omaha NE
Do those carbs have a pipe that comes up in the float bowl from the overflow? If so check and make sure that the pipe isn't cracked. I had to replace a float bowl on my vm26s I just fit on my 77 because of that.
09 Kawasaki ER6n
Omaha NE
- jim_palmore
29 Jul 2008 20:00 #229043
by jim_palmore
that hole was where it poked through removing the old seats. gonna make a cut off valve and eliminate the whole petcock all together. have to watch that I don't run outta gas with no reserve and all
- Sandy
- Fly High,Tony
- Thank you received: 13
29 Jul 2008 20:26 #229047
by Sandy
1977 KZ1000 A-1
Replied by Sandy on topic carb still leaking
Take a CLOSE look at the carb unions(tee-fittings),where they go into each set of carbs and make sure they're not leaking.
I went through that years ago,thinking it was my bowls leaking the whole time,but it turned out to be the unions.
I pulled the carbs off the rack,and used teflon tape to reseal the unions,and it work great.I had those carbs on for about 3 years after,until I put the 29's on.
1977 KZ1000 A-1
