Petcock - stuck in position
- KOOL RYDER
- KZ 650B2 / KZ 1000E
24 Jul 2008 13:05 #228087
by KOOL RYDER
Rockin\' a KZ650B2 since 2007 and a KZ 1000E since 2008
1978 KZ650B
1979 KZ1000ST
Petcock - stuck in position was created by KOOL RYDER
Ok so I removed the petcock from the tank, cleaned the mesh screen and dismantled the front of the the petcock.
It is the single vaccume style stock 78 KZ650 B style with the 2 phillips screws.
Anyways my question is this, When I removed the handle I found out what was wrong with it, the O ring had snapped and was binding the handle. I removed the old ring and replaced it with a new ring, put the housing back together and it moved freely.
The other day when I went for a ride I figured I was getting low on fuel, I went to switch it back to reserve and the handle was all bound up again, less that 2 days after I rebiult the thing.
Is there a type of grease or lubricant that I can use to keep this thing from locking in position that will not afffect the bike? I had only used WD40 to clean it and "lube" it, but I knw that it is not really a lub repacement, what shall I use for this purpose?
Kool Ryder
Kool Ryder
1978 KZ650B
1979 KZ1000ST
- mtkawboy
- Thank you received: 16
24 Jul 2008 13:38 #228095
by mtkawboy
Replied by mtkawboy on topic Petcock - stuck in position
Maybe silicone grease, never tried it
- PFC FNG
- I've got the sickness!!!
24 Jul 2008 16:07 #228109
by PFC FNG
I know it would not be any fun if it was easy, but does it have to be this much fun?
84 ZX750 GPZ (Waiting for paint)
Eastpoint, Mi
Replied by PFC FNG on topic Petcock - stuck in position
I used a dab of motor oil (it's all I had at the time). Just don't use too much.
Eastpoint, Mi
