80KZ750 LTD H1 Carb question
- twfields79
21 Jul 2008 19:39 #227545
by twfields79
1978 KZ650 B2
80KZ750 LTD H1 Carb question was created by twfields79
Ok I just finished putting the top half of my motor back together and Cylendar 2 is not firing except Idle and about 7 rpm...... I set the float level to specs checked coils changed spark plug wires (had two bad ones) and now #2 cylendar is running pretty rich and like I said only hitting at idle and about 7.5 rpm...... Any suggestions would be great I havent rechecked the float level in 2 carb yet I will start there but any other input or suggestions would be appreciated......... I did check the synchronization with a single gague and they all were the same..... Thanks guys
1978 KZ650 B2
- twfields79
22 Jul 2008 20:33 #227768
by twfields79
1978 KZ650 B2
Replied by twfields79 on topic 80KZ750 LTD H1 Carb question
Well I rechecked the float and all is well...... That number 2 cylindar is still flooding Im not sure where to go now..... the others are running great tan color spark plugs everything is perfect...... except that number two cylindar.... Any advise would be greatly appreciated....
Thanks
Tim
Thanks
Tim
1978 KZ650 B2
- twfields79
29 Jul 2008 20:46 #229050
by twfields79
1978 KZ650 B2
Well I figured out what the carb problem was the number two carb was missing the needle valve completely!!!! Online wanted 30 in town wanted like 40 and I took a shot in the dark and checked a small podunk bike shop and they had one on a set of junk carbs just like mine charged 2 dollars and walla...... KZ750 runs like brand new...... I am in Awww..... This is my first bike ever and rebuilding the motor and the head..... and carbs turned out to be a great experience!!!!! Thanks to this site and a service manual and workshop manual......
1978 KZ650 B2
