How do I check float levels.....?
- tgutz
21 Jul 2008 17:03 #227517
by tgutz
How do I check float levels.....? was created by tgutz
I need to check float levels, how do I do it with the carbs on and also when they are off the bike?
Bike is a 78kz650sr, thanks
- Thank you received: 2098
21 Jul 2008 17:45 #227524
by Patton
Replied by Patton on topic How do I check float levels.....?
Use clear plastic tube method, regardless of whether carbs are on the bike or off the bike on the bench. Carbs to be "level" during measurement. Good Luck!
- JMKZHI
- Thank you received: 48
22 Jul 2008 05:09 - 04 Dec 2008 07:19 #227590
by JMKZHI
Replied by JMKZHI on topic .
del
Last edit: 04 Dec 2008 07:19 by JMKZHI.
- bountyhunter
- Thank you received: 337
22 Jul 2008 12:28 #227668
by bountyhunter
Replied by bountyhunter on topic How do I check float levels.....?
I used a thin piece of plastic tubing that I tapered the end on (with an X-acto knife) to be able to jam it into the hole in the bowl that the drain screw is in. Mickey mouse, but it works.
