Fuel in vacuum port covers?
- AutoXN
21 Jul 2008 15:12 #227502
by AutoXN
Kevin
1978 KZ 650 B
Fuel in vacuum port covers? was created by AutoXN
Has anyone ever seen fuel in the vacuum port covers? I was doing a carb sync and all 4 had fuel in them. There is no fuel coming out of the overflow tubes so just can't figure out why so much fuel would get past the carbs.
Kevin
1978 KZ 650 B
- JMKZHI
- Thank you received: 48
21 Jul 2008 15:20 - 04 Dec 2008 07:19 #227503
by JMKZHI
Replied by JMKZHI on topic .
del
Last edit: 04 Dec 2008 07:19 by JMKZHI.
- 76 LTD
- Thank you received: 1
21 Jul 2008 15:28 #227506
by 76 LTD
Replied by 76 LTD on topic Fuel in vacuum port covers?
if you pull one off and it doesnt have gas in it it means your outta gas.
- AutoXN
21 Jul 2008 16:53 #227516
by AutoXN
Kevin
1978 KZ 650 B
Replied by AutoXN on topic Fuel in vacuum port covers?
I figured it was normal but the amount seemed excessive. Just wanted to make sure. Thanks for the info!
Kevin
1978 KZ 650 B
- JMKZHI
22 Jul 2008 05:39 - 04 Dec 2008 07:19 #227596
by JMKZHI
del
