keihin diaphragm
- mopar4u
- KZ 200
21 Jul 2008 07:37 #227423
by mopar4u
keihin diaphragm was created by mopar4u
80 kz440 ltd
noticed one of the diaphragms has a hole(s) in it. I'm aware you can purchase these from germany for a lot of $$ but I'd like to try and fix it. I've seen some ideas on how to fix them but I can't find any info on how to clean the rubber. What is best to clean the rubber that won't eat it so I can prep it for glueing? rubbing alcohol, carb cleaner, soap and water????????
- Old Man Rock
- Thank you received: 225
21 Jul 2008 16:51 - 21 Jul 2008 16:54 #227515
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic keihin diaphragm
Not sure what carb's you have but check here...
sudco.com/diagram.html
These seem reasonable... Again, pending your carb model...
www.atlanticjetsports.com/keihin_jetting.htm
www.denniskirk.com/1/3/keihin-carb
Old Man Rock
Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 21 Jul 2008 16:54 by Old Man Rock.
