Petcock position????
- 1978KZ
1978 KZ1000 A2, 2008 Honda Ruckus, 2004 Nissan Titan
- HerrDeacon
- Thank you received: 1
- Gman
- Thank you received: 5
1978 KZ1000
1965 Harly Electra Glide
2002 Gold Wing
1974 Z1 900 project
- 1978KZ
If so, easy way to tell would be to see if you can get both sides of the handle to point at the Prime position. If it's like mine, you won't and so it's easy then to tell which end if the pointer.
Don't know why I didn't think of that HERR. The long end "IS" the pointer. Thanks
- Old Man Rock
- Thank you received: 225
Whoa, going to leave that one alone for it will start a whole slew of non Bike related replies... :laugh:
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- Locozuna
"long end "IS" the pointer"
OMR
SAYS WHO???????
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
- 1978KZ
- Gman
1978 KZ1000
2002 Gold Wing
1974 Z1 900 project
- Thank you received: 2098
OK, I figured out the petcock, but it is either bad or I have my fuel lines routed wrong. It is a 3 port vacuum petcock: 1 out the bottom and 2 out the sides. I have the small port hooked to the vacuum port on #3 carb. Do each of the other ports go to 1/2 and 3/4?
Do each of the other ports go to 1/2 and 3/4? YES; and doesn't matter which petcock out goes to which carb fuel intake nipple.
With all three lines disconnected, fuel should pour from petcock in PRI position.
Could attach a clean spare hose to the vacuum port. Then suck on it to create vacuum while petcock's in ON or RES position, and fuel should pour from petcock.
Sometimes the diaphrams fail whereby the vacuum doesn't allow fuel flow in the ON or RES position. But the PRI position should always flow fuel.
Be sure there's enough fuel in the tank for the ON position.
Re-test with fuel tank CAP ajar (to test for possible clogged vent which could disallow fuel flow).
Good Luck!
For those special viewers, hope it's recognized that this response manages to get "nipple", "suck", and "diaphram" in the same post. :laugh:
- 1978KZ
:laugh:
