29mm smoothbore carb #1 leaking out pod
  • NickW900LTD
  • NickW900LTD's Avatar Topic Author
  • Nick
16 Jul 2008 23:12
#226657
Im using a non vaccume petcock. Leaking when petcock is on, any ideas whats going on and how to fix?
1976 KZ900 LTD (sold)
1977 KZ1000 LTD
1978 KZ1000 A2A
Pierceton, Indiana USA
  • donthekawguy
  • donthekawguy's Avatar
Re: 29mm smoothbore carb #1 leaking out pod
16 Jul 2008 23:24
#226659
Sounds like they are junk. Go ahead and send them to me and I'll even cover shipping. J/K You either have a bad needle and seat or a piece of crud has found it's way onto the seat. Try taking out the plug of the leaking carb, hold a white cloth under the bowl and open the petcock. It might have enough flow to rinse out the chunk of whatever is in there. This has worked a couple of times for me. If it doesn't work you have to pull the carbs off to have a look. Also do you have an in line filter? If not get one.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • NickW900LTD
  • Nick
16 Jul 2008 23:56
#226662
I have an inline filter allready. Just wondering if it could be a stuck float and could tap on it to set it free?
1977 KZ1000 LTD
1978 KZ1000 A2A
  • NickW900LTD
  • Nick
17 Jul 2008 00:57
#226663
I fixed it, so it seems. I did exactly what you said. So on my lunch break I went outside pulled the drain plug, turned on petcock for about 15 sec then turned it off. Put plug back in and waited a few min and no more leak!!! Thanks for your help bro!!!
Nick
1977 KZ1000 LTD
1978 KZ1000 A2A
  • mtkawboy
  • mtkawboy's Avatar
17 Jul 2008 09:04
#226697
Might want to change the oil, if its running out the pods its running into the motor too, they have no overflows on them
