- Thank you received: 1
fuel injection
- poolboy
1980 KZ750H ,WG's carb rebuild, V&H 4-1 Exh ,WG wiremod, Dyna 3.0 ohm coils, Dyna-S EI DS2-2,New Bridgestones, O-ring Chain,
- Mcdroid
- Gone Kwackers
- Thank you received: 318
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- steell
Dave Sloan used GPz1100 throttle bodies although I think GPz750 Turbo throttle bodies with GPz1100 injectors is a better solution. The Turbo injectors are larger than the 1100 injectors, and unless you are planning to get 120 or more hp out of your 750 (a neat trick) then the 1100 injectors would work better.
Easy is relative, easier for someone like me that is knowledgeable in computers, EFI, electronics, and mechanical, than for someone with no skills. Even someone with no skills can convert a bike to EFI, it just takes longer and is harder.
The cost of converting to EFI is comparable to swapping on a new set of carbs (a small percentage of the total cost of my project bike), and after tuning, the results exceed that obtainable by carbs (usually 10% better fuel mileage and power).
- The Gringo
- ¡Usted no necesita otra motocicleta!
- Thank you received: 11
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
- Mcdroid
- Gone Kwackers
Michael I'm sure you must be thinking of Dave Sloan's bike not Jimmybon's. They are both from down under though.
You are correct Andy...thanks for pointing that out.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- eddieteeth
- GIVE ME YOUR KNOWLEDGE
IM BUILDING AN 810 BIG BORE FROM A 650 AND I NEED SOME ANSWERS.
- Mcdroid
- Gone Kwackers
I like this topic, does any one no where to obtain or how to peice together this system.. I checked ebay i only the dfi box
You can't use the dfi box from a 750 E model...it is configured for a turbo and cannot be remapped. You probably need to PM Dave Sloan (he's a member here) to see what hoops he had to leap through to get where he is...he's a helpful fellow..
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- eddieteeth
- steell
Dave Sloan is a lot farther along than I am, he has a running bike
- Dave Sloan
and I have been collecting parts and modifying stuff to fit on the gpz900 streetfighter I am building (which will hopefully take less time than the house)
Steel I had a look at the original thread in the archives where you, Kzjim and stef were the only ones on the thread, lots of good info there
kzrider.com/archive/viewthread.php?tid=25752&page=4
At htre moment I am running an Ms1 ver 2.2 board with alpha-n ms&sextra code. Gpz1100 tB's, injectors, TPS, fuel reg and pump. The injectors are low impedance and I was running the B&G flyback board but Im not using that ecu at the moment so I am using resistors and have the PWM disabled.The flyback board is on my other ecu which os set up for ignition but I am running a Dyna S at the moment until I have more time to play with the ignition.
I run a tech edge 2EO wide band with a built in display which I use in conjunction with a palm PDA that is used for logging and also as a display, I can also alter the fuel map with the palm. The logs are then downloaded into a target afr program and the VE map altered by the laptop :woohoo: Its Awesome
I was running the ignition through the ms using a vr sensor and a 12-1 toothed wheel but the starting was not good (erratic) as the bikes dont have much flywhell inertia and the crank turns jerky while cranking in part because of the starter clutch design. ArrtuH from the ms forum has come up with a solution using 2 hall sensors reading off of the same wheel that has worked great on his turbocharged gs1100 Suz that I am going to make up once I have more time (read house and GPZ900 fighter finished)
I find that at cruising speed on the highway the throttle is hardly open so the smaller 750 turbo TBs should give a better response although the zx636 Tb's that I have for the GPZ (taoer down to 38mm) are the same spacing as the gpz ones
Dont kow if that covers what you were after but let me know and I will fill in any gaps.
Z650B2 - Injected
