29mm Question
  • badrhino
  • badrhino's Avatar Topic Author
29mm Question
13 Jul 2008 09:43 - 13 Jul 2008 09:47
#225877
When I bought my bike none of the hoses were hooked up to the carbs.
Could someone please tell me what these inlets to the carbs are. I know that the large one is probably for the fuel line from the gas tank. What are the two on the upper outside of the carbs for?
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
Last edit: 13 Jul 2008 09:47 by badrhino.
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
Re: 29mm Question
13 Jul 2008 09:53
#225880
Those are for vent-lines.
Run a length of hose from each one,and route them to the back of the engine,hanging down towards the front of the swingarm.
Do NOT cap them off,or bridge them.;)
1977 KZ1000 A-1
  • FastKaw1
  • FastKaw1's Avatar
Re: 29mm Question
13 Jul 2008 10:03
#225881
Well it has bin some time sense I looked at my carbs I hope I get this right.
The large one in the center between the to inside bowels is gas in.
The two upper ones are (vents) or (over) flow for lack of a better words.
You should have hoses on those as well but they go to the atmosphere.
Hope I got that right.
XENU
  • badrhino
Re: 29mm Question
13 Jul 2008 10:15 - 13 Jul 2008 10:16
#225885
Thanks guys! That is what I thought but wanted to make sure.:blink: Because the upper/outer two look a little high to be overflow vents, wouldn't the gas run into the airbox/pods before it could vent out of the hoses?
Franken Z!
Last edit: 13 Jul 2008 10:16 by badrhino.
  • mtkawboy
  • mtkawboy's Avatar
Re: 29mm Question
13 Jul 2008 10:56
#225896
They dont have overflow hoses
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
Re: 29mm Question
13 Jul 2008 12:03
#225916
It is a fact that the 29mm smoothies don't have overflow lines,and yes,gas CAN seep into the engine.
Try to get in the habbit of turning the fuel off,even for short stops.You'll probably forget to turn it on a few times,before you get the hang of it.
Also...make sure the needles and seats in the float-bowls are in good shape.
Jeff has them(new) at Z1 EnterprizesB)
1977 KZ1000 A-1
  • badrhino
Re: 29mm Question
13 Jul 2008 16:55 - 13 Jul 2008 16:57
#225965
So what are the two outer nipples for?
Franken Z!
Last edit: 13 Jul 2008 16:57 by badrhino.
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
Re: 29mm Question
13 Jul 2008 18:05 - 13 Jul 2008 18:06
#225982
The one in the middle(down low) is your fuel inlet(5/16),and the 2 uppers are for the vent lines.
1977 KZ1000 A-1
Last edit: 13 Jul 2008 18:06 by Sandy.
