29mm
- tanner
- wiredgeorge
Re: 29mm
13 Jul 2008 05:53
Since your wallet will be significantly lighter, your overall weight will be a lot less so you should go faster. On the 75 Z1B, the carbs will not be delivering all the gas that the engine could potentially use at 7500 rpm. You will feel a difference between 7500 rpm and redline. I suspect you would gain perhaps 5 hp on the top of the rpm range and you will feel the difference. For ordinary every day riding where you are not at wide open throttle, not much difference; in fact, perhaps some mid-range is lost over some 26s or even little 24s.
- tanner
Re: 29mm
13 Jul 2008 11:19
thank you how about coils and electronic ignition? i just drive the bike around town and to work doesnt sound like carbs will work .what other little things could i do to run alittle better
- mtkawboy
Re: 29mm
13 Jul 2008 12:15
wiredgeorges coil mod, Dyna S to get rid of points and green Dyna coils & wires. Did wonders for mine
- BohicaBob
- tanner
Re: 29mm
13 Jul 2008 15:21
bike has 28mm on them how do they compare to the 29mm smoothbore?
