zn700 at high RPMs
- LoveLTD
09 Jul 2008 15:30 #225220
by LoveLTD
zn700 at high RPMs was created by LoveLTD
I am looking for some educated help on a carb issue on a zn700ltd. She starts fine and runs great hot or cold right up to about 3500 rpms then things get difficult. Above 3500 I can work the rpms up by slowly giving her more gas. If you just hit the gas hard at any rpm it falls flat. I am thinking that I am running way lean and a good cleaning is in order. I will check the float level also (anyone have the spec for the float level on this bike?)
Any thoughts or advise would be welcome.
- Bluemeanie
- Thank you received: 14
09 Jul 2008 19:45 #225257
by Bluemeanie
Replied by Bluemeanie on topic zn700 at high RPMs
I think you hit the nail on the head. If the bike has been sitting a complete cleaning is in order. I would not do any jetting changes yet as the cleaning may do the trick. Has the bike been modified in any way (4/1 pipe, pods, etc)? I can't help you with a float spec but sounds like some plugged passeges or so. Let us know...
- RetroRiceRocketRider
- Thank you received: 29
09 Jul 2008 22:06 #225277
by RetroRiceRocketRider
Replied by RetroRiceRocketRider on topic zn700 at high RPMs
Welcome to KZr LoveLTD.
I have the FSM in my garage, and can get you the float level specs (or any other specs needed) tomorrow when I get home from work if you'd like?
- LoveLTD
10 Jul 2008 03:33 #225296
by LoveLTD
Replied by LoveLTD on topic zn700 at high RPMs
No mods, the bike does sit stored every winter. I use a gas stablizer and run the carbs dry. The specs would be very helpful.
- Thank you received: 2098
10 Jul 2008 05:53 #225315
by Patton
Replied by Patton on topic zn700 at high RPMs
If not already done, would perform compression test and check valve clearances.
Good Luck!
Good Luck!
- LoveLTD
18 Jul 2008 13:24 #226922
by LoveLTD
If you can get the specs I would be miles ahead thanks.
- wiredgeorge
18 Jul 2008 17:02 #226974
by wiredgeorge
Replied by wiredgeorge on topic zn700 at high RPMs
CV34 and jetting
The CV34 comes in three varieties:
CV34 #1
KZ750E1-E3 1980-82
KZ750H1-H4 1980-83
Secondary main #125
Main #62
Jet needle N01A
Needle jet smaller opening (no badge)
Pilot #35 (pilot well plugged)
To rejet for pods/pipes #140 #70
CV34 #2
KZ750N1-N2 SPECTRE 1982-83
Secondary main #92
Main #68
Jet needle N100
Needle jet larger opening (no badge)
To rejet for pods/pipes #130 - rest stock jets
CV34 #3
KZ750F1 LTD Shaft 1983
Secondary main #100
Jet Needle N10C
Pilot #35
Needle jet (no badge)
CV32 (used on 80/81 KZ250)
Secondary main #98
Main #68
Jet needle N05A
Needle jet no badge
Pilot #35
CV34
KZ440A1-A4 1980-83
Secondary main #88
Main #62 (1980) Main #70 (1981-83)
Jet needle N02A
Pilot #35
CV34
KZ750F1 LTD Shaft 1984/85
Secondary main #98/#88
Main #68
Jet Needle N10D/N10DE
Pilot #35
The service fuel level is 3mm below the gasket mating line. I don't keep track of float level spec as it is a waste of time. Those floats are so bent up from previous owner's ham-fisted bending that it is a waste of time to use the float level spec on the CV34.
CV34 #1
KZ750E1-E3 1980-82
KZ750H1-H4 1980-83
Secondary main #125
Main #62
Jet needle N01A
CV34 #2
Secondary main #92
Main #68
Jet needle N100
CV34 #3
Secondary main #100
Jet Needle N10C
Pilot #35
Secondary main #98
Main #68
Jet needle N05A
Needle jet no badge
Pilot #35
CV34
KZ440A1-A4 1980-83
Secondary main #88
Jet needle N02A
Pilot #35
CV34
Main #68
Pilot #35
- LoveLTD
20 Jul 2008 04:22 #227193
by LoveLTD
Thanks for all the specs Wiredgeorge. I am going to get into the carbs next weekend I hope.
