no fuel
- sdw25
08 Jul 2008 16:01 #224967
by sdw25
dale
crandall,ga
78 kz650 sr emgo pods 4 into 1 exhaust
no fuel was created by sdw25
I have just recently changed over to manual petcock due to leaking origianal used pingel adapter plate and manual petcock from z1 enterprises. Ihave capped vacum line to #2 carb but have no fuel going into carbs I have also cleaned carbs but still no fuel from tank:(
dale
crandall,ga
- Thank you received: 2098
08 Jul 2008 16:23 #224971
by Patton
Replied by Patton on topic no fuel
sdw25 wrote:
Is there sufficient fuel in the tank?
Does fuel flow from petcock?
- Bullitt03737
08 Jul 2008 16:54 - 08 Jul 2008 16:56 #224975
by Bullitt03737
1980 CSR 1000. New dyna Coils, Vacumn Less Petcock, Various Handle bars depending on the day, (Drag and Clubman.)
Replied by Bullitt03737 on topic no fuel
If I understand you have the pingel petcock on there?
If so, the main fuel supply pickup tube is higher than an OEM one. The reserve is pretty much skimming the very bottom on the tank. Try the reserve setting to see if that gets you fuel. If so put more gas in the tank, and use "on" and check agian.
When you reassmebled the carbs did you happen to place the two outside carbs (#1 and #4) in the middle?
Last edit: 08 Jul 2008 16:56 by Bullitt03737.
- sdw25
08 Jul 2008 17:23 #224980
by sdw25
dale
crandall,ga
Replied by sdw25 on topic no fuel
put on reserve and plenty of fuel but still no fuel making to bowls almost like vapor lock or something because it flows fine out of the petcock until you put the fuel line on:unsure:
dale
crandall,ga
- 76 LTD
- Thank you received: 1
08 Jul 2008 17:41 #224982
by 76 LTD
Replied by 76 LTD on topic no fuel
vent in the cap may be plugged or more likely the float valves are stuck(happened to me).i had cleaned and replaced the carbs and let them sit on the bike dry for a couple days and they stuck.i pressurised the tank with an air hose and unstuck them.doesnt take much 10 psi. or less.just wrap a rag around the air nozzle to seal it to the tank.
- Bullitt03737
08 Jul 2008 18:12 - 08 Jul 2008 18:13 #224986
by Bullitt03737
You could also try just tapping the carbs with a rubber mallet.
If you think its a vent. Thats a simple check, just open up the lid on the tank and see if you get fuel to carbs.
Last edit: 08 Jul 2008 18:13 by Bullitt03737.
- sdw25
08 Jul 2008 18:20 #224988
by sdw25
dale
crandall,ga
thanks for the help will try the sugggestions and see what happens:)
dale
crandall,ga
