Another Petcock Question - From KOOL RYDER
- KOOL RYDER
- KZ 650B2 / KZ 1000E
08 Jul 2008 09:47 #224888
by KOOL RYDER
Rockin\' a KZ650B2 since 2007 and a KZ 1000E since 2008
1978 KZ650B
1979 KZ1000ST
Another Petcock Question - From KOOL RYDER was created by KOOL RYDER
I have a 78 KZ650B2. I have also reviewed the petcocks on the Z1 website, but I am a little aprehensive about installing a new one.
Can someone reccomend a new petcock that will bolt on without any hassel? I can measure the bolt distance.
I still have the stock petcock in place, but it is seized and I can no longer turn it to reserve position an I am interested in taking a long ride to the coast and could really use the peice of mind that the reserve will provide.
1978 KZ650B
1979 KZ1000ST
- Locozuna
08 Jul 2008 09:55 #224892
by Locozuna
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
Replied by Locozuna on topic Another Petcock Question - From KOOL RYDER
If it's a shut off one (does not have a PRIme setting). Take the old one apart. They are pretty simple really. Usually a new O ring and some grease, clean the screen bowl and they are OK.
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
- RonKZ650
- Thank you received: 240
08 Jul 2008 11:31 #224906
by RonKZ650
Replied by RonKZ650 on topic Another Petcock Question - From KOOL RYDER
1978 would be the vacuum petcock. Easily identified by the fact there are 2 philips screws that hold a plate on the side that surrounds the petcock handle. If this is what you have, and the vacuum part of the petcock is not leaking, you can repair the seized handle real easily by simply removing the 2 screws, the handle comes right off, lube it up, maybe replace the oring, but may not even need that. This doesn't goof up the vacuum part, as no need to fool around with it at all if it's working. You'll have to drain the tank first of course. If you have the manual petcock, throw that POS away, no use even trying on it.
- JMKZHI
- Thank you received: 48
10 Jul 2008 05:48 - 04 Dec 2008 07:07 #225312
by JMKZHI
Replied by JMKZHI on topic .
del
Last edit: 04 Dec 2008 07:07 by JMKZHI.
