Carb. mount boots?
- stevekx
10 Jul 2008 13:33 #225387
by stevekx
1980 kz250g - keihin pw26 carb
Replied by stevekx on topic Carb. mount boots?
Are those carb holders pure rubber? Do they have gasket material on the flange?
- NiagaraZ
11 Jul 2008 13:55 #225599
by NiagaraZ
78 KZ650 D1
Replied by NiagaraZ on topic Carb. mount boots?
The replacements from Z1 seemed to be all rubber, same as the originals there might some metal inbeded in them but no gasket material.
Like anarki650 i replaced the airbox boots too, come to think of it, i've replaced most of the rubber bits over the last few years...
78 KZ650 D1
- wiredgeorge
11 Jul 2008 18:38 #225632
by wiredgeorge
Replied by wiredgeorge on topic Carb. mount boots?
The carb holders sold by Z1Enterprises.com are all rubber with the vacuum ports only exiting the right side. They are made by the SAM COMPANY in Japan as made the OEM. I like to leave all four vacuum ports pointing to the right when I work as it is easier to get the hoses on from underneath for me from my manometer. I have a set of long needle nose pliers for installing the hose on the #2 carb port. The others are an easy reach.
- OLTIMER
- Back when I was your age, ...
- Thank you received: 1
11 Jul 2008 20:14 #225650
by OLTIMER
1978 KZ650-D1 SR
Sioux Falls, SD, USA
The shortest distance between two points is under construction.
Replied by OLTIMER on topic Carb. mount boots?
Kthx, sounds like I will be replacing them then.
But, if I can get the machine on the road for a little while yet this summer / fall, I will try using the old ones - then replace them over the winter.
1978 KZ650-D1 SR
