extra hoses comming out of my KZ750's carbs
- Strible
06 Jul 2008 17:11
so im looking over my bike as im putting in new oil and i notice four rubber hoses comming out of my carbs, that lead no where there just grouped together and poited out behind the engine. There are two big hoses and two very small ones. There is also two large hoses leading form the gas tank to the two carbs, which i get. but these four that lead no where confuse me a bit. there is allittle gas coming out of them, and i recently had a problem with the gas overflowing the engine. So i am thinking may be these tubes are for if the gas over flows in the carbs some will be pushed out through these tubes. But then agin alot of gas went into the engine which is why i had to change the oil. So maybe im wrong and these hoses are supposed to be connected some where. any thoughts?
, by the way i have a 1979 kz750 B , twin engine
- EasyRider1
Re: extra hoses comming out of my KZ750's carbs
06 Jul 2008 17:16
Strible wrote:
Bingo!
Bingo!
1978 KZ650C
- Strible
- EasyRider1
06 Jul 2008 18:17
Well, the hoses that come out from under the carb bowls (bottom) are for draining when too much gas gets in the carbs. The other hoses are for fuel and vacume.
1978 KZ650C
- Sandy
- Fly High,Tony
06 Jul 2008 21:43
You might want to pull those carbs off and go through them.
Check you float heights AND the fuel shut-off valves(needle and seat),as they may need to be replaced(or cleaned up)if you're getting fuel out of the overflow lines.That's a sign.
1977 KZ1000 A-1
