KZ750 Idling Problems
- brox
05 Jul 2008 16:35 #224282
by brox
From Bismarck, ND
1981 KZ750 LTD w/Kerker Header
2006 KTM 200 XCW
KZ750 Idling Problems was created by brox
I finally got my bike to run great throughout the RPM range. The only problem is now, the idle won't stay. When I set it, it seems to fluctuate. And when I release the throttle, it is slow to drop down to idle. When I stop, the idle hangs, then slowly drops and will eventually die out. Any ideas? Bike is a 1981 KZ750 LTD. Thanks.
From Bismarck, ND
2006 KTM 200 XCW
- OKC_Kent
- Thank you received: 20
05 Jul 2008 19:52 #224314
by OKC_Kent
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
Replied by OKC_Kent on topic KZ750 Idling Problems
Check for an air leak in your manifolds. Spray WD40 on each manifold, if the idle changes then you need to seal the leak or replace the manifolds.
Also make sure your throttle cables are the proper length and routed correctly. Lube them and make sure they don't bind.
Oklahoma City, OK
- brox
06 Jul 2008 14:52 #224479
by brox
From Bismarck, ND
2006 KTM 200 XCW
Replied by brox on topic KZ750 Idling Problems
It was the manifolds. I put new K&L manifolds on in April, and no matter how much I tightened them, they would leak. Luckily, I saved the old ones. Everything working now.
From Bismarck, ND
2006 KTM 200 XCW
