Must Remove Carb To Install Throttle Cable?
  • davehayward1
  • davehayward1's Avatar Topic Author
05 Jul 2008 16:13
#224280
The speedometer and clutch cables were shot on my '81 KZ 750 LTD so I replaced them
I tried to replace the throttle cable and got stuck.
It looks like I have to remove the carb
Has anyone done this?
Can I do it without removing the carb?
  • Locozuna
  • Locozuna's Avatar
Re: Must Remove Carb To Install Throttle Cable?
05 Jul 2008 16:43
#224283
Loosen the locking nuts on the rear cable mount and remove the cable from the bracket. That will give you enough slack to line the cable up with the slot to remove the barrel. I use a flat screwdriver to push it, pointed pliers or a set of hemostats. Once that is done the front is usually the same way. I find the back easier and ONCE done gives the front cable more slack. Your experience may differ! :blink: GLuck! B)
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
  • JR
  • JR's Avatar
05 Jul 2008 19:44 - 05 Jul 2008 19:48
#224311
I have a 1980 750 4 cylinder and find it easier to take off the carbs to hook up or unhook the throttle cable. There is not much space in there :) I just have to pull them a tad back out of the carb holders to give me enough room to get fingers in there.
I do have pods which makes the job is a bit easier than if I had an airbox..
locozuna, I like your idea of using a hemostat. I should pick one up at my local surplus store
Last edit: 05 Jul 2008 19:48 by JR.
  • SPARKY47
  • SPARKY47's Avatar
  • 1980 KZ500 B2
06 Jul 2008 05:52
#224366
Excuse me, what's a hemostat?:blink: :blink: :blink: :blink: :blink: :blink: :blink: :blink: :blink:
1980 KZ500 B2
  • JR
  • JR's Avatar
06 Jul 2008 13:08
#224458
"whats a hemostst ? "
One of these thingies
en.wikipedia.org/wiki/Hemostat
Looks like a scissors but instead of blades the ends are like needle nosed pliers and the gismo between the finger grips allows you to clamp it. Very usefull for working with tubing ;) ..... or I imagine working with throttle cables. I've often seen them in my local surplus store in the tools section.
  • Locozuna
  • Locozuna's Avatar
06 Jul 2008 13:23
#224461
Dats dem!!
Back in the day they were also called "roach clips". But I digress. They are pretty handy dandy things and come in all kinds of configurations.
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
  • exoskel
  • exoskel's Avatar
  • transcend...
06 Jul 2008 13:58
#224469
Some of us still call 'em that!
1979 KZ750B4
1998 Yamaha Blaster
South Bend, Indiana
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
06 Jul 2008 14:22
#224474
Hey,thanks for the heads up on the hemostats!:woohoo:
Just bought these ones...
Hemostat
1977 KZ1000 A-1
  • violentvintagecycles
  • violentvintagecycles's Avatar
06 Jul 2008 15:50
#224487
Locozuna wrote:
Dats dem!!
:P :laugh: :woohoo: lmao
  • SPARKY47
  • SPARKY47's Avatar
  • 1980 KZ500 B2
06 Jul 2008 16:18 - 06 Jul 2008 16:20
#224500
Thanks JR, I'm sure they've got something like that in our local "hospital".
Time to wander "lost" around the place:woohoo:
Bloody Hell, posted first part of this post then followed the link.
Spooky.
1980 KZ500 B2
Last edit: 06 Jul 2008 16:20 by SPARKY47. Reason: spooky
  • Locozuna
  • Locozuna's Avatar
07 Jul 2008 05:50
#224593
I'd just like to take a moment here to speak about the astronomical cost of rolling papers and it's effects on todays society. Because of this incredulous scalping of prices the Hemostat industry has been set on it's head and the once thriving manufacturers of these medical and head shop items have been reduced to selling on ebay and reportedly being used by mechanics, model builders and tubing manipulators. Shame on us for letting this happen. I call on Congress to look into ZigZag, EZ Wider, Bambu, JOB, Juicy Jay's, Joker, and Rizla's pricing schemes before it's too late. B)
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
  • ronjones
  • ronjones's Avatar
07 Jul 2008 06:59
#224605
Hemostats are too useful as an all around tool, to be used as a roach clip...an alligator clip is a much better roach clip, cheaper also. Or just use a pipe:silly: :side: :woohoo:
