Need help finding carb parts
- 1978KZ
04 Jul 2008 22:52 #224159
by 1978KZ
1978 KZ1000 A2, 2008 Honda Ruckus, 2004 Nissan Titan
Need help finding carb parts was created by 1978KZ
I recently got a 78 KZ1000 from a guy that had carb problems. The problem was the bleed pipe and main jet were missing from the #1 carb. Does anyone know where I could find a bleed pipe?
- exoskel
- transcend...
05 Jul 2008 09:08 #224231
by exoskel
1979 KZ750B4
1998 Yamaha Blaster
South Bend, Indiana
Replied by exoskel on topic Need help finding carb parts
I always check e-bay.com, denniskirk.com, and babbitsonline.com first!
1979 KZ750B4
1998 Yamaha Blaster
South Bend, Indiana
- 1978KZ
05 Jul 2008 10:41 #224244
by 1978KZ
Replied by 1978KZ on topic Need help finding carb parts
I ordered one from Babbits today but I think that I will get told it is discontinued. That is what happened at the bike shop.
- bountyhunter
- Thank you received: 337
05 Jul 2008 14:18 #224264
by bountyhunter
Replied by bountyhunter on topic Need help finding carb parts
The good news is that the KZ1000 was the police bike so there are probably a zillion of them around. The dismantlers will have used carbs available.
- mtkawboy
- Thank you received: 16
05 Jul 2008 15:07 #224272
by mtkawboy
Replied by mtkawboy on topic Need help finding carb parts
I have some from various years if they are all the same. Some out of a 76 and some out of an 80. What size main jet?
- 1978KZ
05 Jul 2008 19:03 #224302
by 1978KZ
I think that all the VM26 carbs are the same(Please correct me if I'm wrong). 105 main jets
- wiredgeorge
05 Jul 2008 19:24 #224307
by wiredgeorge
Replied by wiredgeorge on topic Need help finding carb parts
There are quite a few VM26 assemblies and the jetting is different in each.
- 1978KZ
06 Jul 2008 06:24 #224381
by 1978KZ
Maybe someone can help me determine what type of carbs I have. I could not find any numbers at all on the carbs. But here is a description of the carbs:
1. The Idle screw is one large knob on the top, rear center.
2. The return spring is one long one instead of being on the shaft.
3.The bowls have a small drain screw with the drain hose on the bottom center.
4. I measured across the engine side of the bore and it was 33/32" which converts to 26.19mm. ( I dont have calipers)
5. Here are some pics of the carbs
- 1978KZ
06 Jul 2008 06:26 #224383
by 1978KZ
Forgot to say that the last picture is the part I need and can't seem to find.
- mtkawboy
06 Jul 2008 10:04 #224422
by mtkawboy
I definetly have the jet holder, if it will work. Ill have to check on the jet in a little bit and get back to you. Dont know how good the O-ring will be either. If you want them after I look Ill give you them and you can send me what ever the postage is or screw me out of it, Whatever you decide:laugh:
- mtkawboy
06 Jul 2008 11:30 #224437
by mtkawboy
I have one that looks identical to the picture and the 105 main jet. You will need to find a new O-ring. Email me at mtww55@msn.com if you want it
- kawsakiman
- Thank you received: 6
06 Jul 2008 14:26 #224476
by kawsakiman
Replied by kawsakiman on topic Need help finding carb parts
i have one for you also.
i will sell of give away parts to someone who is not a customer.
