Tuning 33mm smoothbores
- BigBlockT
04 Jul 2008 20:50 #224126
by BigBlockT
Tuning 33mm smoothbores was created by BigBlockT
Since the carb manifolds do-not have vacume ports to tune the 33's can you drill,tap the intake side of the head like you do for nitrous?
- wiredgeorge
05 Jul 2008 15:48 - 05 Jul 2008 15:50 #224279
by wiredgeorge
Replied by wiredgeorge on topic Tuning 33mm smoothbores
Don't see a reason why you couldn't drill/tap intake runners. I have installed vacuum spigots from an old set of carb holders into a set of larger carb holders. It is kind of a pain to get them out of the old rubber but it can be done. If you drill/tap, you will have to use adapters to do the sync but if you modify the rubber carb holder, you can just shove the hoses from the manometer onto the vacuum fittings you installed.
Last edit: 05 Jul 2008 15:50 by wiredgeorge.
- BigBlockT
05 Jul 2008 16:46 #224284
by BigBlockT
Replied by BigBlockT on topic Tuning 33mm smoothbores
thanks.
