ninja carbs- going on the kz.. pics added
- School Teacher
04 Jul 2008 14:37 - 09 Jul 2008 10:44 #224044
by School Teacher
1976 kz900 in parts but will be going some day soon
1980 kz1000G1
1976 kz900 parts bike
1979 kz1000 shaftie parts bike
1978 kz1000 33mm smoothies 1075 kit
Troutdale Oregon USA
ninja carbs- going on the kz.. pics added was created by School Teacher
eventually i'm reracking some 34 kehnin from a 84 gpz/ninja for my kz- anyone see a problem with this? they don't have slanted bowls so i thought i got'em use them. anyone know what it would be like compared to say some 29's
thanks
thanks
1980 kz1000G1
Last edit: 09 Jul 2008 10:44 by School Teacher.
- wiredgeorge
05 Jul 2008 15:46 #224278
by wiredgeorge
Replied by wiredgeorge on topic ninja carbs- going on the kz
I am thinking the carbs on the 84 GPz900 are 36s. In any case, if you want to use constant velocity carbs, try some BS34s. If you want a challenge, rerack the Keihin GPz carbs. You will find that it might be more of a challenge than you initially think as the sync arm paddles won't align and you will have to modify the rod that works the choke plungers. Not saying it can't be done but just not worth the effort, imho. The slanted bowls are the kiss of death. I don't think they can be made to work because I have tried... wg
- JMKZHI
- Thank you received: 48
05 Jul 2008 18:37 - 04 Dec 2008 07:08 #224292
by JMKZHI
Replied by JMKZHI on topic .
del
Last edit: 04 Dec 2008 07:08 by JMKZHI.
- wiredgeorge
05 Jul 2008 19:25 #224308
by wiredgeorge
No, the 84 GPz900 carbs are painted (actually powder coated) and look pretty much like BS34s. I think they are 36mm by the way but am not positive.
- School Teacher
06 Jul 2008 16:26 #224502
by School Teacher
1980 kz1000G1
Replied by School Teacher on topic ninja carbs- going on the kz
they are 34's the 1100's came with the 36's as far as i know,
well i re- racked them to a point. (used some aluminium angle) tomorrow i fix the sync tab and choke slide bar but my next question would be the fuel tee needs to be longer now any suggestions on what would fit?
also bs34 did they come stock on the j models?
when and if i finish i will post some pics
1980 kz1000G1
- School Teacher
08 Jul 2008 01:21 #224838
by School Teacher
1980 kz1000G1
ok reracked and got the choke bar and the carb sync tabs taken care of gonana search out a fuel tee tomorrow
1980 kz1000G1
- galaxian
08 Jul 2008 08:12 #224875
by galaxian
1977 KZ1000A1, 1979 KZ650 C3
Replied by galaxian on topic ninja carbs- going on the kz
Can you just fit tubing between the T's to take up the space?
- School Teacher
08 Jul 2008 17:00 #224976
by School Teacher
1980 kz1000G1
actually thats what im' gonna try but i need to cut the tee and it doesn't give much "bite" room with the fuel hose.
if this doesn't worl im looking at making one from scratch i guess.
1980 kz1000G1
- School Teacher
08 Jul 2008 22:23 - 08 Jul 2008 22:31 #225069
by School Teacher
1980 kz1000G1
ok here are the pics the work isn't the prettiest but no one will see between carb 2-3 it works and lines up now for mounting and testing for leakage
1980 kz1000G1
Last edit: 08 Jul 2008 22:31 by School Teacher.
- School Teacher
08 Jul 2008 22:34 #225070
by School Teacher
1980 kz1000G1
1980 kz1000G1
- School Teacher
08 Jul 2008 22:35 #225071
by School Teacher
1980 kz1000G1
1980 kz1000G1
- School Teacher
08 Jul 2008 22:36 #225072
by School Teacher
1980 kz1000G1
ANY GUESS ON JETTING?
1980 kz1000G1
