clear plastic tube test
- jon0108
03 Jul 2008 10:46 #223753
by jon0108
clear plastic tube test was created by jon0108
1983 KZ750F1 LTD Shaft
I did the clear plastic tube test and found out that the service fuel level is very high on the 2 carbs on the right side of the bike.
A few weeks ago I had gas leaking out of the carbs when i shut the bike off. I ordered a new vacuum petcock and that solved the problem. However after some research on this forum I learned that gas shouldnt leak when the bike is off regardless of the petcock, as long as the floats/valves are properly adjusted in the carbs.
What could it be? A few months ago i had the carbs apart for cleaning and made sure the float height was correct.
- bubbap
- Ride it like you stole it!
03 Jul 2008 11:23 #223763
by bubbap
1979 KZ650, Mac 4-2 exhaust. Restored after 25 years of sitting. Dyna elec coils, ignition. As old as I am, been in the family since new.
Replied by bubbap on topic clear plastic tube test
Did you use the bench test to set the float height? I tried that, had them all set, and had the same problem. I had to do the tube test to get them set right. Takes a little time to get them just right.
- anarki650
- Thank you received: 5
03 Jul 2008 12:08 #223775
by anarki650
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
Replied by anarki650 on topic clear plastic tube test
+1 on the bench test being basically worthless. I can't even begin to tell you how many times I tore into my carbs because of float height before I got smart and made myself a clear tube meter.
09 Kawasaki ER6n
Omaha NE
- OKC_Kent
- Thank you received: 20
03 Jul 2008 13:11 #223786
by OKC_Kent
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
Replied by OKC_Kent on topic clear plastic tube test
jon0108,
I've always admired your bike, I have the same model in disarray in the garage right now. She'll never be as nice as yours as the original paint is long gone, but I'm doing my best.
Can I persuade you to add some close-ups to the KZ750 picture Gallery? It sure would help me in my rebuild.
Kent
Kent
Oklahoma City, OK
- bountyhunter
- Thank you received: 337
03 Jul 2008 22:31 #223872
by bountyhunter
Replied by bountyhunter on topic clear plastic tube test
anarki650 wrote:
Amen.
Amen.
- HerrDeacon
- Thank you received: 1
04 Jul 2008 03:38 #223885
by HerrDeacon
Replied by HerrDeacon on topic clear plastic tube test
What do you guys use to screw in the drain hole to attach the clear tube to? What is the thread size/pitch of this hole?
- OKC_Kent
04 Jul 2008 05:12 - 04 Jul 2008 05:40 #223897
by OKC_Kent
Oklahoma City, OK
HerrDeacon,
On the 650 I use whatever size tube I can force fit in the drain hole. It stays in long enough to get the float set.
Some guys will also take a plastic vacuum fitting of slightly larger o.d. than the threaded bowl outlet, and screw the fitting in the bowl. The metal bowl cuts the thread into the fitting as it screws in. Then just attach
the tube.
I am posting pictures from Odd Ivars great site for the KZ400. www.kz400.com
the tube.
Oklahoma City, OK
Last edit: 04 Jul 2008 05:40 by OKC_Kent.
- HerrDeacon
04 Jul 2008 18:01 #224086
by HerrDeacon
Perfect, thanks OKC. That's a great idea to use plastic and just thread it in there.
