jetting 26mm a 1000
- School Teacher
01 Jul 2008 23:42 #223437
by School Teacher
1976 kz900 in parts but will be going some day soon
1980 kz1000G1
1976 kz900 parts bike
1979 kz1000 shaftie parts bike
1978 kz1000 33mm smoothies 1075 kit
Troutdale Oregon USA
jetting 26mm a 1000 was created by School Teacher
ok i have a stock set of 26mm from a 76 900 and am putting them on the 1000g i have, the flapper door(or something) went bad on my fuel injection
what jets do i put in? not just the mains i mean all of 'em
thanks in advance
thanks in advance
1980 kz1000G1
- School Teacher
01 Jul 2008 23:43 #223438
by School Teacher
1980 kz1000G1
Replied by School Teacher on topic jetting 26mm a 1000
oh i have kerker with a baffle and pods
1980 kz1000G1
- wiredgeorge
02 Jul 2008 05:35 #223462
by wiredgeorge
Replied by wiredgeorge on topic jetting 26mm a 1000
You don't have to do much with the 76s. Rich from factory. Put on some larger mains... perhaps #120s.
- School Teacher
02 Jul 2008 22:34 #223669
by School Teacher
1980 kz1000G1
if i am running lean with this set up should i be looking for air leaks? other? what? sorry
1980 kz1000G1
- wiredgeorge
03 Jul 2008 05:29 #223690
by wiredgeorge
What set up? The 26s with 120 mains? If you are lean with the 76 carbs with 120 mains, there is some other problem... air leak would seem likely. What makes you think you are lean?
- School Teacher
03 Jul 2008 14:33 #223792
by School Teacher
1980 kz1000G1
well i was running 130's and was lean on the plugs on all four and sprayed some starter fluid in "key places" and found some air leaks i was suspecting.(since the leaness)
fixed air leak and it was rich
im getting some 120 today will report later
thanks
thanks
1980 kz1000G1
- School Teacher
04 Jul 2008 14:23 #224040
by School Teacher
1980 kz1000G1
ok slapped the 120's in and much better gonna go for another test ride and buy some new plugs-
as far as performance are 26's a step backward compared to the kdfi fuel injection?
1980 kz1000G1
