Question about the air screw on kz 550 81 ltd
- bkemp
01 Jul 2008 20:44 #223418
by bkemp
Question about the air screw on kz 550 81 ltd was created by bkemp
1981 Kc550-c2 ltd
In my Haynes Workshop Manual it shows the carbs having a air screw but on my carbs I see a silver looking plate I think covering the area. I was told on some models that they just filled in where the air screw should be.
- loudhvx
- Thank you received: 1616
01 Jul 2008 23:10 #223434
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic Question about the air screw on kz 550 81 ltd
The air screws are under the silver plates. Make sure you are looking at the correct plates, though, because there are several that should not be opened. If you are sure you are looking at the right plates, you can just poke a really really sharp awl into the plate and pull it out. I don't like using drill bits because they can go in too far and damage the screw. The plate or plug is about 1 mm to 2mm thick.
1981 KZ550 D1 gpz.
Other links.
- bkemp
02 Jul 2008 10:15 #223505
by bkemp
Replied by bkemp on topic Question about the air screw on kz 550 81 ltd
I have never herd of an awl. Were can you get one and for what price?
- rstnick
- Thank you received: 377
02 Jul 2008 10:48 - 02 Jul 2008 10:55 #223511
by rstnick
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Replied by rstnick on topic Question about the air screw on kz 550 81 ltd
Welcome.
You can get an Awl at a hardware store (or similar) for not much money, maybe a few dollars. A dental pick, or anything pointy and strong could work.
Here is some info in my manual on removing the plugs:
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Last edit: 02 Jul 2008 10:55 by rstnick.
